1999 F-150 Evaporative Emissions Control System
I took the truck to AutoZone for diagnostics. Service Engine Soon light had come on day before. They did not show me the code, but said it registered a "Large Leak in the EVAP". I asked a few questions and they said a small leak is usually a gas cap, large leak is normally hose related.
I have done a ton of work on this truck and try to do everything myself. I have the Haynes Repair Manual.
Can anyone give me an idea where to start? What does this large leak probably mean?
Any help is appreciated. Thank you.
If the gas cap has a minor leak in its seal with the fill tube, it will come up as a small leak. Thats why here in PA as part of emissions inspections they must test gas caps as well. My wife sport trac just trew the code, I looked at the tubing on the evap system and didnt see any problems. For what the cap costs, I would start there first. Then if that doesnt fix it, look at your rubber tubes next.
DSparksF250
11-07-2016 11:06 AM
grcutter
08-18-2011 12:24 AM
