ignition upgrade
Old Jul 14, 2008 | 11:21 AM
bshackelford711's Avatar
bshackelford711
ignition upgrade
i am looking to add an elctronic ignition conversion to my 390.
I am also going to change to coil and do the entire setup.
Which would be the best choice for a full setup???
What would be the improvments?
Thanks
-Brandon-
Old Jul 14, 2008 | 06:51 PM
bluesky636's Avatar
bluesky636
I use Pertronics.
Easy to install, trouble free operation, looks totally stock, improved starting and idle, smoother operation in general.
Others may disagree and that is their right.
Old Jul 31, 2008 | 10:02 PM
waltbou's Avatar
waltbou
Pertronics has helped my truck ive got a 73 with a 390 fe and i havent had a problem with it and it was easy to install
Old Aug 1, 2008 | 10:37 AM
coores14's Avatar
coores14
I got my Accel ignition kit on sale at Summit for dirt cheap. Simple to install and works like a champ.
Old Aug 1, 2008 | 11:48 AM
maxtor's Avatar
maxtor
MSD is hard to beat. There are many advantages to their system.
Old Aug 1, 2008 | 12:37 PM
Redmanbob's Avatar
Redmanbob
Went with the Crane Xri, works ok / easy enough to install / has a built in rev limiter (4-6-8 k) for when your relatives/kids/friends etc... need to use the truck
Only thing I didn't like was the wire is a little rigid and when it's really cold the adv plate didn't want to slide due to the wire binding at the entry hole. Some rerouting (looping the rotor) solved that issue.
Old Aug 1, 2008 | 06:00 PM
montana_highboy's Avatar
montana_highboy
Duraspark II (blue grommet) they're readily availabe and cheap and more then adequate for a stock or mildly built 390.
Old Aug 8, 2008 | 02:16 PM
wikedscot's Avatar
wikedscot
I was considering Accel or MSD, I'm glad you asked this question Brandon, I didn't realize that there were so many options. I've got a '67 that has had a 390 4V swapped.
I want to do a fulll ignition upgrade, and now it looks like more research ahead!
Old Aug 8, 2008 | 06:31 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
If you have an even-stock 4bbl 390, it's got higher than the normal truck motor. Which means you could use extra voltage, or the multi-spark setup, especially when you get into a bigger cam and cold weather.
I ran a Duraspark setup for years and fought the cold-startup, low RPM driveability issues. I installed an MSD 6AL with a standard MSD coil (pretty much a stock electronic ignition coil) and it made a WORLD of difference.
Of course, I had a lopey cam, 10.5:1 compression.
In your case, a Pertronix or similar setup will bolt-in, hookup, and do away with the points. And if your upper distributor bushing is shot and the dwell is walking all over the place, it'll definitely make a BIG difference.
But I wouldn't pass on an MSD or other multi-spark setup either if you can do wiring for yourself.
