Stereo Upgrade -- Ford CD6 w/ MP3
In 2005 ford put CAN (controller area network) into to all of the superduties, I suspect there is a plug change to accommodate the data that transits through the radio. However 99-04 should be pinned the same. 05+ could be the same, but I wouldn't expect it to be and would verify it before trying a newer radio.
http://replacementradios.com/product...roducts_id=367
I finally scored a factory Ford in-dash 6-disc changer that plays MP3s, from ebay. It plugged to my original harness and clipped into the dash just like my single CD unit.
I would appreciate any feedback to see if there's any info that should be added or removed or any other pics that would be helpful.
I have been wanting to play my MP3s but my stereo does not do that (it is the 6-CD changer in the dash though). My CD changer is on it's last legs (punching the dash isn't as effective as it used to be) and this is moving up my list of "to-do" items. I have been using my iPod with an FM tuner transmitter but that's pretty much junk at best. I don't really want to buy an aftermarket stereo since I don't really plan on going crazy with the system. Just something that has some good power coming out of the head unit. Plus the stock look deters any would-be thieves since nothing I've done changes the appearance of the truck (I still have the stock wheels too).
Is there a chart or list of some kind that shows what Ford stereos are MP3 compatible and which plug configuration they fit? Or is there a link I don't know about to a thread that already has this and I'm looking like a fool ?
If not, I'm going to have to start cruising eBay looking for a double din Ford Stereo (6 CD preferable, I've been spoiled...and yes I know that 1 CD will hold over 100 MP3s) with "Folder" buttons on it.
Excellent write-up! Reps sent.
Unfortunately in '05 they went with a much fancier interior, including a newer head unit design that's just a bit taller than the double din design I have, otherwise I would have already PM'd you!
Thanks anyway.
Thanks anyway.
Yes it does. You can separate them into different folders (rock, country, etc) and select the individual folders on the disc. I think I usually get something like 100ish songs on one disc.
I found this a few days ago. Maybe it will help you find a radio that will fit: http://www.issford.com/issford/radio_guide.pdf
http://cgi.ebay.com/ebaymotors/ws/eB...i%3D1&viewitem=
I didn't feel like getting in a bidding war, not to mention I found one where the bidding STARTED at $150. Most of the ones cheaper than $100 to start didn't look so good anyway (or weren't the Audiophile). Now I don't have to get an install kit or an adapter...straight plug and play. As an added bonus I was able to get an Audiophile unit (higher power) and hopefully the speed sensitive volume works too (I thought it was kind of dumb until I rode with my dad in his truck). The best part is I can change it out on my lunch hour when it arrives. I though about going aftermarket (with a USB port), but I'm not going to expand much more than I have now (except maybe some new speakers).
There was one I almost entered a bid on, but passed for the one I got. It's an Audiophile 6 CD in-dash with MP3. If anybody's interested here's the link:
http://cgi.ebay.com/Ford-Audiophile-...d=p3286.c0.m14
The item doesn't end until 7:17pm tonight (Pacific Time).
#28
I thought about starting a new thread to this but I decided to just add to this one.....
Today I installed a PIE adapter to my stereo so that I can use the "SAT" input as an aux audio input.
I mounted a 3.5mm jack to the dash so I can use a double-ended 3.5mm plug cable to attach the audio device.
Works like a charm.
http://www.frontiernet.net/~jmray/F250Stereo.htm#PIE
Works like a charm.
#29
Sorry to dig up an old thread, but I have been looking for an audiophile radio for months and I finally got one! For $65 too!
Audiophile 6 disc in-dash headunit: FORD:eBay Motors (item 250539711706 end time Dec-06-09 14:03:06 PST)
Now I gotta get the wiring adapters. Thanks for all your help and advice, guys.
