'55 F-100 Cowl panel install
I'm putting a full length cowl panel on the driver side of a '55 F-100. Does the top seam take some type of sealer and how would it be put in if I'm mig welding it on the inside ? It was filled with bondo when I took it apart and couldn't tell how it was originally done. Would I be better off welding it from the outside, then smoothing and painting it ? Could eliminate water leak problems in the future. Thanks for all input, Joe
Cowl panel
Thanks for the info. It is the seam in front of the driver door by the upper hinge. Looked to me like it could be mig welded from the inside and sealed however the factory did it. Weld and smooth may eliminate a bunch of head aches though. Sorry I don't know how to post a pic from my camera to here.
Stoned06
12-09-2015 07:56 PM
Connecticut Calvin
04-05-2015 09:26 AM
svooom
16
11-21-2005 10:29 AM
