2014 6.7 Warnings Go Crazy
I just purchased a 2014 6.7 diesel F-250 with 39K miles. After about 1500 miles it has started to go crazy every once and awhile. All of a sudden it starts to give me warnings in rapid succession starting with "Maintain Advance Trac", then "Low oil Pressure", Engine Overheated", Check Brakes" and more. The water and oil gauges go to "0". I stop, put it in park, set the parking break, and then release it. Everything clears at that point, gauges come back. What is going on?
There's been a number of threads where posters with weird electrical issues have found a wiring harness located by the emergency brake pedal was loose and moving; they secured it and seemed to fix the issues.
You say that you engaged the parking brake (and released it), so maybe you also jiggled the harness enough to temporarily fix it.
Look down by the pedal.
alreadydeadford
02-01-2011 08:36 PM
Tonyhca
03-16-2004 05:59 PM
