6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
08 F350 6.4 with check engine light
Old 07-08-2008, 07:37 AM
vloney's Avatar
vloney
vloney is offline
Got one in here now with CEL. Lifted, 22 inch tires, MBRP dpf back, aftermarket intake. Codes for dpfe correlation (back pressure numbers dont add up), MAF, IAT. Has a brake line leak where its rubbing the frame (installing the lift, he had to relocate the line). He's screaming about "new truck, allready needing repairs!". Here we go again! Will they never learn?
Old 07-08-2008, 11:53 PM
SANDDEMON08's Avatar
SANDDEMON08
SANDDEMON08 is offline
yeah thats been a common porblem. If its a AFE intake they usually throw codes you got if used with a DPF back aftermarket exhaust. I had that problem tell i got my DPF delete tune.
ozark1
07-06-2017 06:00 PM
Dave042
04-01-2016 09:17 PM
Order and Chaos
Garage & Workshop
08-19-2015 01:57 PM
trekbasso
1999 to 2016 Super Duty
02-05-2011 09:05 PM
northernmoose
Offroad & 4x4
05-27-2009 08:37 PM
Quick Reply: 08 F350 6.4 with check engine light
