2007 Mercury Grand Marquis suspension into a 72 F100
#106
That does not sound too bad. I am getting ready when I have a little money to start ordering the fuel system parts. I think I might be able to use the sending unit from the grand marquis. Since you mention making a whole that the sending unit will fit into, this does not sound too bad. I think though I am still going to try to use the original wiring harness from the GM and the stock computer. I am looking at that until I know the motor will run strong.
SS
SS
#107
Not to worry Shoestring. Your right the sending unit is in the wrong place. But a small piece of metal welded over the old hole takes care of that.
I plan on using the fuel pump from the Mach 1. I cut out the support the fuel pump slides into and the upper access port the wires and lines come out of. I will just weld these to the old Stang tank and press on. I do need to install a roll over valve and a vent, but those are also coming off the Mach 1 tank too. The fuel inlet neck is also being reused from the Mach 1 and I just need to get it fabed up and mounted under the bed. I plan to just have a small door at the rear of the bed to acess the fuel filler.
SS
#108
Wow...Great post you have going here. I have a 63 short Uni and just picked up a wrecked 05 CVPI for the front suspension swap. Thanks to this post, now I'm thinking I can swap the entire drivetrain. I would really like to have a mod motor in my slick.
Can the PATS be removed from the 05 CVPI computer or do I need to buy a different computer? What do I need to keep from the 05 CVPI in addition to the motor and tranny?
#109
#110
#111
I think it is possible to use the wire system. You will have to have the gas pedal though and the plug that goes up to the firewall. I have mine, wires have been cut but I have the parts, but I have not hooked anything up and tried to make it work. I would advise though to search ebay and purchase a wiring diagram for your year model vehicle.
#112
I dont have the fuel system hooked up yet. A slight hiccup occured. So the projects got to wait. I did get my drive way slab laid and the drive way will be paved soon.
As for the fuel system, I had considered going with an external pump with the pick up area being baffled inside. But Ive already got the Mach1 stuff, so best to use it.
#113
#114
One project at a time! I am now doing some research on how expensive it will be for me to get a fuel tank made localy. I am going to be using the stock crown vic stuff so I will have to go with a custom tank. I want this truck to be rolling on its own power before i tackle any body work.
** Fill the old tank up with water before you go cutting on it, you dont want to explode**
It would save you some money versus having a custom tank made. Plus the old Stang tank fits so perfect between the frame rails and its 22 gallons.
#115
If the crown vic fuel pump was internal, the fuel tank has to have an access cover or plate to be able to remove the fuel pump and level float. If it does, cut it out and weld it to an old stang tank. Plus the internal fuel pump has to have some kind of support inside the tank, cut it out too and use it!
SS
#117
As far as the truck. Ive got to fab up the fuel, brake, and hydro lines. But right now its all talk as uncle sam threw me a curve ball and my project has got to wait.
#119
not yet, im still deployed. Im counting the days down. Ive got a large pile of parts that ive bought since being gone.
Some parts that I have bought:
4:10 gears for 8.8 IRS
Gear install kit
Helper air bags for Mark VIII IRS
-8AN braided steel fuel hose
-8AN 100 micron filter
Mega Squirt
Mega Squirt relay board and harness
Dakota Digital dash Kit
18 circut Painless wiring kit
Sony head unit with Ipod hook up
Eclisps 6X9 speakers
Hurst Indy shifter
#2 pool ball
CNC parts for hydro clutch
3" in/out polished stainless steel mufflers
Dark blue carpet from 1AAuto
Polished left and right head light buckets
Parts that I still need to get
A load of parts from DC, about 550 worth of rubber parts
Sound deadener off Ebay
3" stainless steel exhaust piping
Stainless Works 2003 Maruader full length headers 1,000
Wheels 500
Tires 600
Monstaliner kit 250
Classic Auto air 775
Wide band data logger 229
A load of parts from Rock Auto totalling 450
Gear install kit
Mega Squirt
Hurst Indy shifter
#2 pool ball
Wheels 500
Tires 600
Monstaliner kit 250
#120
Deployed? Wow, had no idea. Thank you! I read something about you getting your airframe license - hopefully that keeps you away from getting shot at. If not, keep your gun clean & do whatcha gotta do.
It does sound like you've done a fair bit of shopping, too.
I bought a rear-ended 04 CV PI & have been gutting it in my garage next to my 63, so I can get started on the swap. Plan to use the entire drivetrain, supsension, brakes, rims & tires, master/booster/pedal assy, antilock, computer, harness, etc tight down to the aluminum driveshaft. I think it's going to be a lot of fun! Glad I just reread the last few posts about fuel tanks & pumps. I'll make sure I pull the sending unit/fuel pump assy out of the old tank if I can't make the tank fit someplace int eh truck. If you're bored, my buildup's in the 61-66 forum.
