Comp height
Old Jul 6, 2008 | 09:40 AM
mark a.'s Avatar
mark a.
Comp height
If your 400 crank needed turned anyways would offset grinding it to say .030 get the stock piston up high enough in the bore to make much of a difference. Seems like it might be a good idea + a little more stroke.
Old Jul 6, 2008 | 01:06 PM
hollenjoe's Avatar
hollenjoe
you`ll need a larger rod and offsetting more you crank, where are you gonna get this?
Old Jul 6, 2008 | 03:50 PM
mark a.'s Avatar
mark a.
I'm just wondering that because the stock pistons sit so far down in the deck that maby some offset grinding might get them back up without doing anything else ?
