Exploded view of 55 272 Distributor
Old 07-05-2008, 09:09 AM
restoringmy46's Avatar
restoringmy46
restoringmy46 is offline
restoringmy46 is starting off with a positive reputation.
I cann't find a pic of a 55 ford distributor. I finally pulled mine out lastnight and found a wire that had a bad spot on it. It's the wire that connects to the points and runs under or out to the coil. This wire connects to the condenser to. I need to look at this wire better and I need to find out if I can get one to. Thanks
Scott B.
Old 07-05-2008, 11:46 AM
4tl8ford's Avatar
4tl8ford
4tl8ford is offline
4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold
Old 07-05-2008, 12:21 PM
bobj49f2's Avatar
bobj49f2
bobj49f2 is offline
bobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant futurebobj49f2 has a brilliant future
The wire that runs from the top of the points to the insulated bolt on the side of the distributor case has bit me twice, once in my F-2's flat six, and again in my panel's V8. It's a very easy thing to overlook but a very part to check, and the truck won't run if it's broke or shorting out.
Old 07-05-2008, 01:53 PM
Old F1's Avatar
Old F1
Old F1 is online now
Old F1 has a good reputation on FTE.Old F1 has a good reputation on FTE.Old F1 has a good reputation on FTE.
Replace it with a rubber one (napa has them, lw??) you will never need to change it again.
[IMG][/IMG]
Old 07-05-2008, 03:19 PM
bobj49f2's Avatar
bobj49f2
bobj49f2 is offline
Thanks, I didn't realize they made one. I'll have to check out the next time I go to NAPA, which will this week sometime.
Ordnance
08-26-2014 09:14 AM
95 F150 Dude
01-24-2009 02:34 PM
pitbulls20
01-05-2008 11:15 PM
scott289
02-22-2003 09:22 PM
scott289
02-10-2003 11:25 PM
Quick Reply: Exploded view of 55 272 Distributor
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
