How many of you??????
I used the EZ Wiring 21 circuit harness in my 49. I think its a great harness for the money. I agree that the instructions are a little bit lacking and could cause some panic somehead scratching for some people. Overall, the install went very well and I would definately buy their product again.
Bobby
Bobby
Hi all,
I`m using a Enos Black Box and highly recommend it.
Take a look Enos Custom Components, San Luis Obispo
Gary
Gary
I installed an EZ Wire Harness in my 51F1 5 years ago. I had to replace the Flasher units but outside of that I have had zero problems. I liked the price it was around $175.00 for the 21 Fuse colored wire loom. If I was going to install another harness tomorrow I would go with the same one again.
I think it helps to lay it out on the floor and start at one end and work your way thru the harness just to see where everything is. You will see where it goes thru the firewall and what stays in the cab. I found this helpfull.
The only problem I have is the headlights are on and the switch is off. I called and they say I have a wire on the switch wrong. It is a real pain to release the handle. Still fighting this to see what I did wrong.
Max E
Max E
hm.. my book shows all the wires in their bundles.
I moved a couple, and deleted a couple, but it was pretty straight forward.
(trunk light, & power antenna I don't need!).
dome light I moved to the interior section
brake light & power moved to the dash section (switch on the hanging pedal assembly).
moved some of the external light wires from the dash section to the steering section (moved them closer to the light switch).
Sam
Sam
