How many rear crossmembers on an F-1?
on
I removed the bed from my 49 F-1 today. Aside from the large crossmember that the emergency brakes attach to going rearward I have just one crossmember which is located adjacent to the rear spring shackles. Is this correct or should there be another one in the middle somewhere? The one I have is bowed about two inches and has stress cracks at every rivet hole. I don't think I can straighten and repair it. Does anyone have a spare from a junked 48-52 frame? I may need a couple if there are supposed to be more than one. If not, has anyone tried replacing the rear stock crossmembers with something else? What did you use?
This is the first time I've worked on an F-1 frame. I am surprised at how flimsy the frame is compared to the F-2/F-3 with which I'm more familiar. The F-1 is only 1/4 inch channel but my F-3 had 3/8 channel. The top and bottom frame rails are also wider in some places on the F-2/F-3 than the F-1. I don't remember this being mentioned before as I thought the frames were the same except for length...
on
Thanks for the pictures guys and girls. Apparently, I'm not missing any crossmembers. I even have the small angle iron one which I thought had to be something a PO had added...had no idea that was original. The one closest to the rear is the one that needs replacement. Anybody got a spare or have any suggestions as to what I should use to replace it with? If I have to improvise does anyone see a problem with welding it in instead of bolts or rivets?
ajbremer
10-11-2023 10:43 AM
tubolove
05-16-2010 09:23 AM
51dueller
03-01-2006 07:32 PM
Ford_Man_302
07-04-2005 05:42 PM
