A/C intermittently blowing through dash vents
I have 2002 EB Expedition with EATC. When I am using the A/C either on auto or manual the A/C will blow from the dash and then sometimes go through the dash vents. I can get it to blow through the vents again if I change rpms. Any ideas? I searched but could not really find anything.
Thanks
Mike
Thanks
Mike
I am about to start troubleshooting the same thing, and as it started, figured it was a vacuum leak right off the bat.
Did you find the problem?
Mine is a 2003 Navigator with the automatic controls, dual A/C.
I was hoping it was the line into a vacuum canister or something like that. Taking the dash apart will not be very fun. But, I think I can get to the back of the control panel relatively easily...
Hopefully there is a common fix - so if you have fixed yours, let us know. Now, on to further "searching"...
Problem was (at least so far) in the 4 adapters that take the hard vacuum lines to their associated parts:
- Vacuum canister (rectangular behind the battery)
- The two check valve set up where it takes vacuum from the engine and sends it to the above canister and to the a/c control vacuum line which goes through the "firewall" (though we can't call it that, right...)
They were really soft and the black wiped right off...
Changed them using vacuum lines - no cost...
Didn't have the time to write the other day that I checked the two check valves (on this year, they have two of them - one is a Y-check valve, the other is the basic single check valve) that make up the overall assembly that distributes the vacuum to the canister and to the line that feeds the dash controller. However, I checked them for functionality - did they suck vacuum in only one direction - if that is what you mean.
I also checked for leakage on the canister itself.
Both checked out o.k. Although - I tested with my older vacuum tester that has developed a slight leak, so I ended up using the old faithful sucking and using your tongue as the gauge...
I did just buy a better vacuum tester so I guess I will recheck.
The whole assy is only $15 at the dealer, so if anyone finds a problem, it is best to get the hose assy with the fittings, hard lines and the two check valves. Not a bad deal. I did not get it because it was an order and I needed to use the ride, so I just replaced the vacuum lines that adust their size with regular vacuum lines...
Maybe I'll T a vacuum gauge in the line and monitor the engine vacuum while running down the road and see what is going on there when it happens.
It defaults to this when vacuum is lost to operate the doors.
The wife's 02 expo had the same issues. Used a hand vacuum pump also used for bleeding brakes, to pull a vacuum on the box behind the battery and the smaller line going into the firewall. That one would not hold a vacuum. So I inspected the line and could not find anything so now I'm thinking it's under the dash. Jump ahead 1 week, I realized it was going to be a major pain to to pull the dash apart and went back to the line under the hood again for another closer inspection. Sure enough, 3 very small cracks I missed the first time. This hose is formed with a bend. I straightened out line to find them. Quick fix, cut 2" of the line, worked the rubber boot off with a jewler's screw driver to break the glue and slipped it back on the hose. Back to factory specs and the wife is happy again.
JasonBrod
1997-2006 Expedition & Navigator
38
06-24-2018 05:57 PM
1993 ford
09-07-2017 09:26 AM
bulletpruf
1999 to 2016 Super Duty
08-01-2013 11:08 PM
