Maintence Questions
Old Jul 3, 2008 | 11:27 PM
agcntry's Avatar
agcntry
Maintence Questions
Just got an 02 4.0 4x4 auto. It has 88k on it. Any prevenative maintence I should do or things to watch for. U joints, transfer case, rearend,brakes, any things to watch on this truck.
Old Jul 4, 2008 | 03:23 AM
PW01's Avatar
PW01
Do you have any idea what maintenance was performed by the previous owner?
Old Jul 4, 2008 | 08:13 AM
agcntry's Avatar
agcntry
Don't have any clue. The truck appears to be really clean, and drives good. I'm going to get underneath today and see what things look like
Old Jul 4, 2008 | 04:11 PM
michigan66's Avatar
michigan66
Do you have the Owner's Manual? If so, check the maintenance schedule. If 60K miles is a major service point, check over the engine to see if it looks like those services were performed. If not, that should be the starting point for maintenance work. If the major service point is 90K miles you know what is coming up fairly soon.
Old Jul 4, 2008 | 05:09 PM
bazzman1953's Avatar
bazzman1953
Check your tire pressure.
Assuming that you have LT and not 'P' tires installed then boost the pressure. 42psi seems to be the sweet spot as a trade-off in ride and extra milage on my X-cab 4x4.
YMMV as I toss gas on the fire...
Old Jul 5, 2008 | 10:21 AM
sfcwoodret's Avatar
sfcwoodret
I'm sure the tranny needs a flush.
Old Jul 5, 2008 | 02:23 PM
PW01's Avatar
PW01
Since you don't have any idea what has been done, I'd do it all. 90k is a major service point anyway, so I'd do the following ...
-flush coolant
-flush transmission, including filter change
-transfer case
-both differentials
-fuel filter
-clean throttle body
-new brake fluid
-I replaced my upstream 02 sensors, and thermostat
-new power steering fluid
-inspect brakes, hoses, and exhaust
Old Jul 5, 2008 | 05:22 PM
reddog99's Avatar
reddog99
Ditto what PW01 said...
Dean88
16
Sep 29, 2011 11:41 AM
gappy
Oct 17, 2009 08:58 PM
twjull
Aug 19, 2006 11:37 PM
Clint40
Apr 30, 2005 10:27 AM
TrickbII
Bronco II
Jan 26, 2005 10:16 AM
