horn repair/rebuild questions
Old 06-29-2008, 11:28 AM
cars2cool
cars2cool is offline
cars2cool is starting off with a positive reputation.
Does anybody on here know of a company that repairs or restores the electric horns found on our era of pickups originally? I have a pair of sparton horns and the high side will not adjust as per the shop manual. The low tone one is within specs and sounds great. Any help would be appreciated. If it makes any difference I'm looking at a 12 volt horn.
Old 06-29-2008, 03:27 PM
Julies Cool F1
Julies Cool F1 is offline
Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.
Hi C2C,
12V, 6V no matter, I'm using 6 Volt trumpets on a 12 Volt circuit. Needs a 12 volt relay and they are quite a bit louder on 12 volts.
I fixed my horns and actually cut down a second set to complete the cord (so now I have 4 of the big trumpets in my horny little F1 - tee hee). What a MANIAC!
Seriously, as I recall, those are adjusted by points gap (and a good ear). Maybe your points are burned. Did you try cleaning them with a points file or pinch and drag a piece of 280 wet/dry between the points?
Also, clean everything in there really well. Dirt, dust and old hard WD-40 will "tighten" them up too.
Just a thought
J!
Old 07-02-2008, 01:57 AM
t900enforcer
t900enforcer is offline
t900enforcer is starting off with a positive reputation.
When I rebuilt my Sparton Horn I put a new resistor in it to adjust the tone. I don't remember to exact value but is was either 1 or 2 Ohms.
Good Luck
lindenj
2017+ Super Duty
02-07-2017 12:17 AM
reamer
05-11-2016 09:26 PM
Marty in PA
01-25-2011 09:11 AM
1957F100
06-28-2009 12:00 AM
oskie
01-27-2006 12:38 AM
Quick Reply: horn repair/rebuild questions
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
