Axle code?
Old Jun 28, 2008 | 06:35 PM
dave75's Avatar
dave75
Axle code?
What is the axle code for a limited slip dana 60 rear end? Thanks
Old Jun 28, 2008 | 06:44 PM
camperspecial65's Avatar
camperspecial65
what year you working on and which drivetrain is in it and are you working on a 2 or 4WD ??
- cs65
Old Jun 28, 2008 | 06:48 PM
dave75's Avatar
dave75
well I'm just asking because there is a junk yard about 2 miles from me and they have a few 70's fords that are all 2wd but if I can identify a 4:10 ratio dana 60 with a limited slip, I plan on putting it in my 4wd f250
Old Jun 28, 2008 | 07:42 PM
camperspecial65
the codes I came up with are only up thru 72...I dont have the code info for 73-up trucks... the codes I came up with are C5..4.8M cap. , G3, 5.05M load rating. Both are dana 60.3E...what the point 3E means I have no idea...If theres a few trucks, it would be easier for whoever has the rear end codes for these and later trucks to have the codes you found on the door tags. That would IMO make it faster to figure out the codes.
Also, on my D60 in my beast the ratio itself is stamped on the tag bolted to the carrier with 2 of the cover bolts...wire brush and sandpaper would be a good thing to bring in that case.
Good luck, cs65
