5.0 EFI to Carb = vibration?
Old 07-06-2008, 08:04 AM
Madmike33's Avatar
Madmike33
Madmike33 is offline
Madmike33 is starting off with a positive reputation.
Originally Posted by f_ford_custom View Post
is it sluggish below 2000? around 3000? or everywhere? I ask because that 1405 is a rich carb, I got a neighbor with a 396, bigger cam, ported heads, longtube headers, and 6al ignition. even with all of this, she runs rich until about 4500. We changed it out for a 750 tuned for fuel economy and it really wakened up. You dont even smell fuel when it warms up now.
It runs rich, but surprisingly not too bad. I'm gonna run it as is a little but I'm considering re-jetting eventually anyways. I've noticed it isn't too sluggish, but capable of more I'm sure. I found it was slugish in the higher RPM's 3000 up, not lower so I doubt it's a rich situation causing it... we'll see I haven't run the truck enough. I'm taking it out for a 100 mile drive today (its first run this long since the swap) so we'll see.
I'm still in the tuning stages so....
Madmike33
Old 07-07-2008, 06:25 PM
gfw1985's Avatar
gfw1985
gfw1985 is offline
Cranky Old Guy
gfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to all
Madmike33: My problem is solved. It was the wrong flywheel. Love what previous owners do. I bought the thing not running and with bad tranny. Time will tell how how much damage was done to bearings before the tranny crapped out. Good luck with yours.
Old 07-08-2008, 12:27 AM
Madmike33's Avatar
Madmike33
Glad you worked out the problem, still looking at mine but it's not enough mess with my head, I'm still getting some of the truck together. Seeing as this motor wasn't meant for a Ranger there's a lot of little things here and there, like I'm making a rad shroud for it seeing that it runs about 10 degrees too warm without one.. anyways I'll post back when I have some news.
Madmike33
Old 07-13-2008, 06:25 PM
f_ford_custom
f_ford_custom is offline
f_ford_custom is starting off with a positive reputation.
have you played with the timing? I'd try backing it off a little, see if it helps. Maybe advance, but sounds kinda like a few degrees into spark knock, since HP spark curves pull off about 3000. have you put on a timing light at 3500? should be about 32-36 deg advanced.
Old 07-14-2008, 08:56 AM
Madmike33's Avatar
Madmike33
No I haven't put a light on it in a bit. I'm going to soon, I like the way you think.... I'm still not sure how to fit a light yet, the motor fits so tight up to everything that I think I might have to move the battery over for timing. Also I probably have to try looking for possible timing leaks... it might be affecting vacuum advance. Do you know anything about dizzy spring changes??? My Pertronix came with different springs to change the timing curve.
Madmike33
Old 07-14-2008, 06:55 PM
f_ford_custom
The instructions will give you step-by-step instructions, but basicly just take off the dizzy cap/rotor, and the springs are right there on top. The insrtuctions will also tell what colors will come in where and when they'll be at full advance. Your kit probably came with an allen wrench if you've got adjustable vacuum advance.
Old 07-15-2008, 12:20 AM
Madmike33's Avatar
Madmike33
Thanx I'll have to try and find the instructions online cause my dizzy box was missing the instructions... to be continued
Madmike33
Madmike33
01-23-2008 12:37 AM
Madmike33
Engine Swaps
12-18-2007 12:15 AM
Madmike33
04-10-2007 02:28 PM
Madmike33
Ranger & B-Series
03-29-2007 12:17 PM
Madmike33
18
10-26-2004 12:41 AM
Quick Reply: 5.0 EFI to Carb = vibration?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
