Archived Alberta Buy/Sell/Trade Ads
#151
My trucks now up in the bargainfinder and other places online. Price is $950
http://www.buysell.com/root/detail/C...g_box_2wd.aspx
#152
Parted out the wheels. Now selling truck 1 for $395. Need this thing out of my parking space.
Ad reads:
1977 Ford F250 Super Cab Camper Special 460 Auto 2wd long box. Camper Special has upgraded brakes, sway bars front and rear, and heavier duty springs, 3675 kg GVW. Front brake rotors, calipers and pads replaced 1500 kms ago. Body has extensive rust, box and frame are solid. Small oil leak from valve cover. This truck has always started regardless of temperature or how long it's been sitting. Great truck for a tradesman or landscaper. Five digit odometer means true mileage unknown. Currently shows 76,xxx miles.
More pictures availible via Email.
Ad reads:
#153
77 F150 s/c 460 for sale
Got a surplus 1977 F150 supercab here in the red deer area with a healthy 460. BC truck brought from Okanagan. Some rust in box and back of cab but overall decent. Asking $1200.
mike
mike
#155
'77 is SOLD.
Just bought a 2000 Expedition, and I'm looking for a second set of factory wheels for it. Any Expedition or an F150 that's 1997 or newer should fit just fine. Tires not important, since I'm planning on buying some new rubber.
PM me, I can pick up around Calgary and area.
#156
LOOKING FOR ford/Mercury Pickup ( Van style) econoline
HI guys, if anybody knows of a ford/mercury 1961 to 1967 econoline truck in very good shape that is for sale please let me know.I would prefer a 65/67 mercury but what ever is out there is going to be ok. Thanks Tony 403-318-6178
#159
I'm a Newbie
Im new, but would like to post a giveaway ad if I could. I am really desparate to give the parts away, before I have to send them to scrap. They are good parts, but I have no Room. JS I have left this post blank because rules say I need to ask permission post being a new member. I cannot even retrieve messages, therefore I must edit this post. I have a 1972 F250 body that is being swapped for a 0% rust 1970 F100. The body parts are all there minus the cab floor (rotted) and Box floor. All parts are in good order and may come with trim. anyone wanting to see what I have my garage is 1972 F-250 base nicknamed George. It is posted on the main page. I appologize for not knowing more about the web page. JS
#160
Wanted: 1982-86 F-150 Regular cab short box 2wd. perfered that it have a 300-6 and a 4 speed. Running condition or not, doesn't matter. Just as long as it is a roller and the frame is straight we can work with it.
#161
WTB Replacement Expy Wheels (5x135 14mm o/s)
Hi All,
I'm looking for an updated set of Ford wheels for my 2001 Expy.
Stock wheels are 17x7.5 with an offset of 14mm. They are the 5x135 bolt pattern.
Hopefully something relativly local to Calgary.
Thanks, in advance
Rob.
Thanks, in advance
Rob.
#162
http://www.ford-trucks.com/forums/752633-archived-alberta-buy-sell-trade-ads.html
Hope its alright to post this here, i havent read anything that says i cant so here go's:
I wont list everything i have but if you ask i might just have it.
Heres what im Parting out
1970 Ford F100 360, 4 speed (np)
1981 Ford F150 (no engine, trans) but had a 351w, c6
1996 Ford Ranger (no engine) but had a 4cyl, std, ext. cab
1996 Ford Aerostar 3.0L, auto, XL trim, SWB.
Selling 2 sets of e7 heads fully ported or just rebuilt or just mild porting on the exhaust side (one set 5.0, one set 5.8) with back cut stock sized valves and springs.
One set of C6OE 289 Heads with hardened seats, fully rebuilt or ported.
Set of .040 over 390 Flat Top Pistons with Valve Reliefs
2 Holley 600 cfm Carbs
Stock 5.0 HO Roller Cam w/dogbones and retainer.
Stock 5.0 HO lower and upper intake with fuel rail and throttle body
Stock 5.0HO Distributor
EFI 5.8L stock upper and lower intake.
E4OD Trans for SBF bolt Pattern
as well as everything you could possibly need to convert 5.0 or 5.8 with E40D to MAF
Alot of these items will also be available at the Red Deer swap meet on March 26th.
PM me for info, questions, pictures, im open to offers on everything, not really a set price on anything.
#163
Ok folks, I am selling my stock 18’s from my 2011 F-350 SRW.
See my kijiji ad: Stock 2011 18" F-350 SD Wheels & Michelin LTX tires - Calgary Tires, Rims For Sale - Kijiji Calgary Canada.
Either PM me on here or reply to my ad.
Cheers, JC
EDIT: SOLD!!!!
Cheers, JC
EDIT: SOLD!!!!
#165
I have trim pieces from a 75 f250 camper special and frame cross members from a 78 f350 dually. Also have front lights and grill from 89 f350, 351w efi and zf42 with new slave cylinder and release bearing, wiring harness and radiator from the 89. Thankyou
