Oklahoma Chapter Join Chapter, Leader:
Top hot, Bottom cold
Old 11-09-2017, 04:51 PM
Tim Casey's Avatar
Tim Casey
Tim Casey is offline
The top radiator hose on my 90 ranger with 2.9 liter v6 is hot while the bottom radiator hose is a lot cooler, new thermostat and coolant with flush. smells hot though no leaks.
Old 11-10-2017, 08:10 AM
ctubutis's Avatar
ctubutis
ctubutis is offline
So, what is the problem? This is the way it works... hot coolant comes out the top of the engine, flows through the radiator and is cooled, and is returned at the bottom.
Are you sure you installed the correct thermostat in the correct manner (IOW not upside down)? This happens more often than you'd like to think.
Montync
10-07-2015 02:39 PM
lemasters f100
10-05-2013 08:19 PM
joel79ford
12-26-2011 08:59 AM
muchocheko
05-24-2007 09:35 PM
cezarleo03
Bronco II
07-22-2003 07:27 PM
Quick Reply: Top hot, Bottom cold
