New Hood Hinge Question
Old Jun 22, 2008 | 10:19 PM
rnelson664's Avatar
rnelson664
I just installed new hinges from MF. The hood stays open but if I move it down only about a inch it closes in a hurry. If I left it open and someone bumped it or a little wind moved it, it would drop like a rock. Is that normal? When I installed them I used the MF's tool and had to wind it about 180 degrees to hook it on the tab. So I think I installed them correctly. Thanks
Old Jun 23, 2008 | 03:59 PM
fking1's Avatar
fking1
Definitely should not drop that way. My 55 takes a good pull to close. I installed new hinges , but, couldn't get the hood fit to adjust so ended up putting the old ones back on. Work OK.
