Best way to 400HP
Best way to 400HP
I have a fun/pull truck. I brougth a nice old 95 to play with and pull the boat.
The truck seems solid, runs good, looks good, cold air, etc. I would like to play with it and my goal is 400HP still being able to pull my boat (12K#) with out killing the motor.
The truck is stock and this was my thought?
-3" DP
-4 inch exhaust
-Stage 2 injectors
-Napa 6637 filter (already on the truck)
-D66 turbo
-Chip (controlable unsure whos)
What are you thoughts what would this give me on a 170,000 mile truck. Would this kill it? Do I need the D66? Is this a good set up or is there better.
I will be doing the work my self in stages this winter. The budget is about ~5K.
Thanks
-3" DP
-4 inch exhaust
-Stage 2 injectors
-D66 turbo
Thanks
Dieselsite also have the Pulse, and an electric fuel system that is pretty good.
Don't forget about your clutch and some gauges.
I keep reading about the stock thrust bearings being so bad on these turbos...... Why? I have pushed my stocker past 35psi for the past 40-50k miles and its still the original after 270k only changing the wheel. Does the d66 have stock thrust bearings or is it a better aftermarket one? I think that for the air it flows and half the instal price it would be my choice in a new turbo
I have been looking into doing some decent modding to my truck too and I have decided to go with a set of stageIII DIYs, HX50, Pulse, CPx fuel system, TW tunes and a 6.0L intercooler. This should be good for 450-500ish I am thinking... if only I had more money! Good luck with your build though.
better add headstuds and valve springs to that list oh and a full tranny build if your going to be 500 range.
