Front end "popping" noise
My 2001 Expy 4x4 has been making an occassional popping noise most often when turning and backing out of a parking space.
I've searched the forums and have gotten together Moog lower ball joints [$46 ea], Harbor Freight ball joint press kit [$39], their front end press kit [$69] and all the ordinary tools, stands and jacks.
Now I'm wondering if the CV joint in the axle could be bad making the noise.
Thoughts?
Thoughts?
It could also be the mounting link bolts for the ends of your front sway bar. Mine broke due to severe rust, very common on the OEM links. The plastic cover on the link bolt doesn't keep the water out so they disintegrate. Check those and see if they are corroded. One of mine made the same noise cause when it broke, it just flopped back and forth across the a-arm and sway bar during turns. Easy enough to replace in the driveway/garage, just get a set of Moogs or some other quality link kit with good quality bushings.
vze2sgxa
1997-2006 Expedition & Navigator
09-17-2008 05:28 AM
