front brake grabbin
Old Jun 20, 2008 | 09:19 PM
mattsf-100's Avatar
mattsf-100
Question front brake grabbin
Okay guys,
I need somemore help here. The front driveside brake on my 64 f-100 is grabbin. Any ideas where to start?
The brakes look good but I cant find the problem.
Thanks
Matt
P.S. i got the carb problem fixed. My original diaphram had a metal piece around it and the new ones didn't so it leaked. We put the old diaphram back in and she runs good now.
Old Jun 22, 2008 | 02:14 AM
flipklos's Avatar
flipklos
more info? Maby a hardwear kit(springs Etc)
Old Jun 23, 2008 | 11:21 AM
64F-100's Avatar
64F-100
Make sure the front passenger side brake is good; mine was doing the same thing, and it turned out that the seal in the wheel cylinder was leaking, causing the drum to get slick.
Old Jun 23, 2008 | 02:52 PM
garbz2's Avatar
garbz2
Did you put self adjusters on it? 64 does not have them and when one side wears more than the other they need to be re adjusted, and they will pull to the side that gets the drum contact first.
A wagner kit for a 65 up will work on the 64 backing plate.
Garbz
Old Jun 23, 2008 | 05:15 PM
airharley's Avatar
airharley
Sounds like you might have to replace the brake hoses if the hardware and leaking wheel cylinder aren't the issue. The brake line can look physically fine on the outside but the rubber swells shut from old age. Think of it like a clogged artery.
mhatlen
Dec 11, 2011 12:54 AM
Crew-it
55
Nov 16, 2011 05:42 AM
shortbed7.3
New Hampshire Chapter
21
Mar 14, 2008 09:20 AM
Polkat
Oct 5, 2002 09:54 PM
moe
Nov 30, 1999 07:58 PM
