poor mileage after lift and big tires - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 1999 to 2016 Super Duty
Reload this Page >
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 06-13-2008, 07:32 PM
yungpup
yungpup is offline
yungpup is starting off with a positive reputation.
I just dont understand this. I put a 10 inch lift in my crewcab longbox f250, I have 38 inch toyo tires on it and have plenty of power with the v10, but my mileage just sucks. I only drive to school and back and never haul anything with it. I thought I would get ok mileage with taller tires. Can anybody help me with this ? I just cant afford to drive this truck now. What am I going to do now ? Gas is $4.16 a gallon here and I only get 7 mpg.
Old 06-13-2008, 07:38 PM
BIG-FUJIMO
BIG-FUJIMO is offline
BIG-FUJIMO is starting off with a positive reputation.
I can help you buy saying if you want to play hard your going to pay hard. Did you think your going to get better fuel milage?
Old 06-13-2008, 08:16 PM
duffman77's Avatar
duffman77
duffman77 is offline
duffman77 is gaining momentum as a positive member of FTE.
Yes, return the truck to stock. You messed up the aerodynamics and increased the rolling resistance. You should have done some research before hand, its a common trait on this board that the lifted trucks with aftermarket tires are getting less MPG than the unmodified ones.
As to reducing your cost of driving, dont exceed 55 MPH, you've got a cool looking truck now, better spend some time being seen in it.
Old 06-13-2008, 08:19 PM
Powerstroke_wannabe
Powerstroke_wannabe is offline
Powerstroke_wannabe has a great reputation on FTE.Powerstroke_wannabe has a great reputation on FTE.Powerstroke_wannabe has a great reputation on FTE.Powerstroke_wannabe has a great reputation on FTE.Powerstroke_wannabe has a great reputation on FTE.
Lift = more wind resistance = lower mileage
Larger tires = more rotating mass = more power required to get them & keep them turning = lower mileage
Old 06-13-2008, 08:36 PM
dew the thunder's Avatar
dew the thunder
dew the thunder is offline
dew the thunder is gaining momentum as a positive member of FTE.
What'd you get before the lift and what gears do you have? Did you change them to compensate for the larger diameter tires?
Old 06-13-2008, 08:39 PM
F350-6's Avatar
F350-6
F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Welcome to FTE youngpup. Unfortunately what your describing is common knowledge. I would have thought this would have come up while looking into the lift.
In case no one has told you, you're speedometer and odometer are no longer anywhere close to being accurate either. Unless you had them recalibrated for the larger tires.
If the speedo hasn't changed then you really don't know what type of mileage you're getting yet.
Old 06-13-2008, 08:52 PM
suzuki0702's Avatar
suzuki0702
suzuki0702 is offline
suzuki0702 is starting off with a positive reputation.
LOL!!!!
Old 06-13-2008, 09:13 PM
ReAX's Avatar
ReAX
ReAX is offline
ReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to behold
Don't forget that your odometer isn't correct. The 38" tires travel further per revolution than the stock 31"ish tires. So your looking at at least 15% difference in actual travel. For rough figure you can add 15% to your mileage, or you can get your speedometer corrected. Even with the 38's, you should get at least 9mpg I would think.
Old 06-13-2008, 09:56 PM
PSD4ME
PSD4ME is offline
PSD4ME is starting off with a positive reputation.
I can mabey help. Send me your tires and wheels and I'll trade you for the stockers.............
Old 06-13-2008, 10:03 PM
BIG-FUJIMO
It doesn't matter what you do to any lifted truck the best fuel milage will come out of a stock truck. I'm getting about 12 to the gallon when I should be getting almost 20. that is chipped up also. That is calculating the bigger tires!! I'm not complaining my truck is more of a yard ordanment than anything as much as it sits.
Old 06-13-2008, 10:26 PM
DAFBFD58's Avatar
DAFBFD58
DAFBFD58 is offline
DAFBFD58 has a great reputation on FTE.DAFBFD58 has a great reputation on FTE.DAFBFD58 has a great reputation on FTE.DAFBFD58 has a great reputation on FTE.
I'm running 35s with my 3.73s and I am getting about 13 around town and will get high 14s to 15+ on some local routes and above 16 on the highway. Oh and I have the 5.4. Live said above bigger tires mean more power to move them. Taller means your like a wall going down the road. Stay out of the skinny lever, and get the right gears
Old 06-13-2008, 10:35 PM
miker67's Avatar
miker67
miker67 is offline
miker67 has a good reputation on FTE.miker67 has a good reputation on FTE.
Bigger tires can lead to better MPG for highway driving. For stop and go driving like you describe it will be worse due to the extra torque needed to get the rig moving. However, the combo you have is over the top and the only way you are gonna get your mileage back is to scale back your rig a bit.
Old 06-13-2008, 10:43 PM
Furian's Avatar
Furian
Furian is offline
You Keep What You Kill
Furian has a great reputation on FTE.Furian has a great reputation on FTE.Furian has a great reputation on FTE.Furian has a great reputation on FTE.
On the positive side, the under side of your truck should be much cooler! Just kidding... If I were you, I would make sure that I have the right gears in the differentials and have the speedo recalibrated. Only then will you know how well you truck is performing. Best success!
Old 06-14-2008, 12:01 AM
QwkTrip's Avatar
QwkTrip
QwkTrip is offline
QwkTrip is a splendid one to beholdQwkTrip is a splendid one to beholdQwkTrip is a splendid one to beholdQwkTrip is a splendid one to beholdQwkTrip is a splendid one to beholdQwkTrip is a splendid one to behold
That truck is a lot of coin for a young kid in school to handle. There's no doubt it's very cool but when you're financially strained to pay for gas then you need a lifestyle adjustment.
So here's the plan: Think "econ car". Get through college so your earning power goes up. This next step is critical. Land your first job and live at home with mom and dad. You won't be able to afford cost of living AND a cool ride until you're much older. So in the mean time you'll just have to make sure you never bring home any girl friends because if you do then won't have any girl friends. But you'll have that cool ride!!!! Vettes, trucks, muscle cars.... whatever! Because you can afford anything now! Another bonus is mom and dad might give you garage parking to keep it nice.
At some point you'll either make enough to live on your own or decide you're just going to give up expensive cars in order to get your own place. At that point girls will respect you and you will get married. When you're married you'll become poor again. So you better make sure that you carry into the marriage whatever you want to drive because you will never get to buy anything cool for another 15+ years. Unless you become a DINK (double income no kids). They drive whatever they want. Usually BMW's because no matter how they begin they always morph into yuppies.
The other option is you can quit school now to become a redneck so you can always drive a cool truck! If you need more information about red necks let me know and I can explain your options.
Old 06-14-2008, 12:59 AM
F350-6's Avatar
F350-6
F350-6 is offline
Note from us old folks. DON'T live with mom and dad after you get out of college. Manage your expenses properly and work your way up to the cool stuff.
The redneck option might be a possibility as long as you don't stay at home too long.
Quick Reply: poor mileage after lift and big tires
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
