To Do lists : Let's see what you got
Ok guys ... lets have some fun and forget the fuel prices for a while. I was thinkging of all the stuff I have to do to my truck that I have sitting ready to do but no time to do it and made a list. Let's see what everyone has on their lists. This is stuff you have sitting there ready to do but no time, not a wish list.
1. Replace nasty carpet with new
2. Install sound deadner on floor, doors, roof, & cab back
3. Install 6.0L cooler
4. Install electric fuel pump system and regulator
5. U-joints are clunking
6. Install new cab bushings
7. Replace all bushing in front end
Man .. I need a crew and some drinks.
What do all you have?
1) wash/wax truck without getting a ticket
2) swap in SD front springs
3) match rear ride height with front
4) get new tires
5) align front end
6) finish building and install OBA system
7) purchase and install toolbox to compliment my stacks
8) relocate both batts to frame rail and rewire system
9) reinstall coolant filter
10) IDM mod
11) SD HPOP
so many projects and so little time!
-cutts-
4) get new tires
5) align front end
10) IDM mod
11) SD HPOP
-cutts-
Things that are waiting patiently for install:
HX50
Add-a-leafs
Oil temp and pressure gauges
Oil micro filter
Things that will be purchased in the near future
A Valair!
CPR+
Pulse
Tuner (Specific product unknown at this time)
Hopefully get around to putting on a high idle before next winter...
HX50
Add-a-leafs
Oil micro filter
A Valair!
CPR+
Pulse
Everything ...
Did the outside last and this year. Also did the 6637, HUGH improvement and fuel pump then bb mod.
Every time I get enough money saved up for down pipes and exhaust mods something happens. Last month my dog 16 years old got sick and rushed her to vet and two x-rays later it cost me $375.00 to kill my best friend. Good grief ...
Oh, I'm working on Bio-Diesel. Small quantity's for now just to get a feel for it and get the procedure down, kitchen recipe. I want to use my old turkey fryer with propane for heat in the future for slightly larger batches. If I can get a 5% mix I'll be happy for now.
oh my, i wont give you the full ist because there would be no room for anyone else's, so here is a few things on the top of the list.
- new transfercase
-bed cancer repair
-paint
-rear diff shims
-center support bearing mods
-stacks
-tw chip
-stage 2's
-big turbo
-big oil
-custom fuel system
-ft axle locker
-40/20/40 seats
-gauges
-new wheels
-spring bushings
-rear rubber brakeline to stainless
-tint front windows
- heavier hitch
-bronco fuel tank
-smoked headlights
i better stop now......
- new transfercase
-bed cancer repair
-paint
-rear diff shims
-stacks
-tw chip
-stage 2's
-big turbo
-big oil
-custom fuel system
-ft axle locker
-40/20/40 seats
-gauges
-new wheels
-spring bushings
-tint front windows
- heavier hitch
-bronco fuel tank
-smoked headlights
Seal the new cargo light with caulk. The last one rotted from leaks. Got the caulking
Seal the lights on the cab. They leak too. Thought it was the wind shield. The cab smells like rotten socks after a good rain.
Make a exhaust hanger. The cat delete did not come with one so the exhaust kind of hangs off the turbo right now. got the steel and mig welder.
Fix the boost leaks in the intake plenum's. Got the sealant for that about five months ago.
Fix the door hinges before I loose a door or passenger.
Get rid of the K@N and install the 6637 i got a few weeks ago.
See whats up with the cruise control that stopped working a long time ago. have a steering wheel puller.
And I have coolant leaks at the thermostat.
O yea, got a fuel filter a week ago but the cap on the old one wont come off because I over tightened it because of leaks.
Boy these trucks leak like a old Harley. Want to see a list for the two old Harley's I got?!?!
Wow, some of you have some major mods on your to-do lists.
My current to do's (generally in order of importance):
-wash/wax job, powerwash underneath
-put the F-250 badge on the different tailgate I just got
-find or order a bed mat
-find an OEM chrome rear bumper
-new tires on the rear
-relocate my trailer plugin after the new bumper
-polish the one headlight that's slightly yellow-the other must have been replaced sometime.
-one-touch down driver's window like I did in my 95 F-150
-find another remote for keyless entry as one of my two is dead
-pack front wheel bearings
-check rear brakes
Sometime in the near future:
-take to the body shop and fix a few minor dings from the PO
-find a better tailgate (the one I just got still isn't perfect)
-chip and guages
-new rear hubcaps (they're still there, but the chrome's flaking off)
-check rear brakes
-chip and guages
When list is complete it will all get installed
sitting in garage
1.Banks PowerPac
2.TW chip(still need to get it reburned)
3.HPX(installing this weekend)
Things to get
1.stage 1's
2.17* HPOP
3.BTS tranny
4.things will always be added....first I can think of is a set of 19.5 Ricksons(which may come sooner since I will need tires in the next couple months)
sitting in garage
1.Banks PowerPac
Things to get
1.stage 1's
2.17* HPOP
3.BTS tranny
on
Let see, to do list.....
Rebuild the stacks (half way done, finish tomorrow)
clean interior and exterior (tomorrow)
Oil change (tomorrow)
install different bypass filter (frantz now Amsoil waiting)
Send chip out for reburn
swap out 7.3 IC for 6.0
build and install Big oil
Build and install big turbo (HX50)
Wish list.....
Got enough things to do above!
Wish list.....
