Hub upgrade or downgrade?
Old 06-12-2008, 08:27 PM
Mydiesel250's Avatar
Mydiesel250
Mydiesel250 is offline
Mydiesel250 is starting off with a positive reputation.
Hello all, first i would like to give huge thanks to texasoutlaw for GIVING me free needle bearings however turns out my problems go deeper than that. Im in need of new hubs. I have an Early 99 f250 psd and i hear that the 99.5 is an upgrade? and cheaper to buy. is this correct and if so do i need any modifications. Also can anyone suggest a place to purchase or is one place as good as the next?
Old 06-12-2008, 08:30 PM
John311t
John311t is offline
John311t has a good reputation on FTE.John311t has a good reputation on FTE.
Replacing the brakes, brake caliper mount, and both hubs are in order to get to a 99.5+style setup.
Old 06-12-2008, 08:31 PM
Mydiesel250
Wow, so the cheaper hubs in the long run really wont save me any money if i have to replace everything else.
Old 06-12-2008, 08:34 PM
John311t
John311t is offline
Well, when you get brakes, you will also need to spec. early 99 IIRC, and those are also more money also. I would look for a junkyard in your area and call about 2 caliper mount brackets, and then just replace with new brakes. Then your front end should be good to go.
Old 06-12-2008, 08:54 PM
Mydiesel250
so i should go with the 99 and up new hub, also when you say i need to spec. early 99 IIRC what is that?
Old 06-12-2008, 08:56 PM
John311t
John311t is offline
Specify sorry, after I re-read that it sounded kinda awkward. The brakes are different on the early 99 also, so if it was me, I would swap everything over from an 99.5+ setup, just for ease of installation later on down the road.
Old 06-12-2008, 09:00 PM
Mydiesel250
Ok thanks, you think ebay would be agood place or should i contact ford directly
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
