do we have a power steering cooler?
Old 06-12-2008, 06:26 PM
swaybar
swaybar is offline
swaybar is gaining momentum as a positive member of FTE.
i have a hose that just started to leak in small drops. the hose goes from the top of the steering box, down to the bottom front of the truck to what looks like a power steering (radiator-cooler), in front of the regular radiator, its a small unit, only like 10inches wide by maybe 4", and the hose connection at the cooler is only a metal clap making me think its not a pressurized line. i ask this cause i need it to drive back and forth to work tommorrow (20 miles round trip) before i can get one and change it out saturday morn. anyone familiar with this i'd love to hear ya chime in with input. gotta log off now but i'll be back by 9pm. thanks bro's
Old 06-12-2008, 06:35 PM
mongo75's Avatar
mongo75
mongo75 is offline
mongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to all
Yeah, it's a PS cooler. The lines are indeed pressurized- go ahead and take it off and start the truck if ya don't believe me LOL. They put those same cheap clamps on the tranny cooler lines too. I only replace them once a leak starts, with a small all stainless screw clamp. You should be fine with a little leak, just kee an eye on it and replace any lost fluid with TRANNY FLUID, not power steering fluid!
rbaker6336's Avatar
rbaker6336
rbaker6336 is offline
rbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to behold
Old 06-12-2008, 07:30 PM
swaybar
swaybar is offline
hey mongo thanks, but what do ya think will happen if the line completely breaks in two? on this line the first few inches are a fitted metal line and then the rubber hose part continues the rest of the way for this hose. now the leak is at the metal part of the hose. if that snaps in two will i lose steering? and/or will i be able to drive. do you think the reservour will empty out that line or would ya think it will just affect the temp of the fluid?
Old 06-12-2008, 07:40 PM
clux's Avatar
clux
clux is offline
clux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputationclux has a superb reputation
If your line breaks it will pump all of your fluid out in very short order. Then you will still have steering but it will be like the old manual steering of 30 years ago--if you remember that. The fluid is also used for brake boost, so you will have manual brakes as well.
Old 06-12-2008, 08:33 PM
mongo75's Avatar
mongo75
mongo75 is offline
Losing power steering is bad enough, but if you lose power brakes on a 7000+ lb truck you will not be able to stop her w/o rear ending the guy in front of you. Is the steel line itself leaking? I highly doubt that- if anything at all it's just residual leaking back up the line from the fan blowing it or driving and air pushing it. You should be good with just a screw on clamp.
Old 06-13-2008, 05:51 AM
Markadeck's Avatar
Markadeck
Markadeck is offline
Gone, but not forgotten
Markadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant futureMarkadeck has a brilliant future
These trucks are all but unstoppable without the PS pump operating. Even both feet won't do it, not for me anyway. But I only weigh 150 pounds.
Old 06-13-2008, 06:43 AM
Izzy351's Avatar
Izzy351
Izzy351 is offline
Izzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud of
Don't forget you have a parking brake. It will help......some.
Old 06-13-2008, 08:51 PM
swaybar
swaybar is offline
well, never drove the truck. got a little worried about losin it far from home. changed it out tonight after work. now i wait for the next fix !!!!!!!!
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
