slight "thunk" coming to stop and
when I begin to accelerate.. I talked with STROKIN'IT7.3 a few weeks ago when we met but forgot exactly what he told me..
When I come to a dead stop I hear a slight thunk, and when I hit the gas I hear it again, like something in the drive train is loose or something..
thoughts? my old mind can't remember what I was explained
The cheapest thing to do is open up the rubber boot just aft of the carrier bearing, drop the rear part of the driveshaft, and grease the splines inside the boot, as that may be what you feel. It's pretty common, especially at those miles. It should take you half an hour.
There's special aquamarine-colored grease that Ford sells in a 3-ounce tube to do it. It's called XG-8, and every good Ford counterman knows about it.
The tube should be good for about five or six lubes, and you may need to do it every year or so, depending on your driving habits.
Use a small brush to apply it to the splines. Be sure to not over-do it, just a nice coating.
Here's the TSB:
https://www.ford-trucks.com/tsb/full...p?tsb=05-26-10
For photos, see Rick's link below.
Pop
Here's the TSB:
Pop
that would be this eh? Slip joint regreasing
only concern with that link you posted is that it states that only when accelerating from a stop, no mention of hearing it when I come to a stop as well.... same thing? cause that definatly fits the acceleration part for sure
I think this is more common to ball joints going out. The drive line regreasing is more common with a thunk from take off. Check both of those points and you'll probably find the source of the noise.
