EcoBoost (all engine sizes) 3.5L Twin Turbo EcoBoost V6, 2.7 Twin Turbo EcoBoost V6, 2.3l/2.0L I4 EcoBoost Engines
ecoboost
Old 05-15-2009, 08:33 PM
REDFORDFX4's Avatar
REDFORDFX4
REDFORDFX4 is offline
ecoboost
By the looks of it the ecoboost will be kind of exspesive,Like $7000,
On the 2010 Lincoln MKS It is that much ouch! and only 24mpg in a car?
Might s well bring on the oil burner for that?
At least for the F-150?
Old 05-15-2009, 08:41 PM
gpp's Avatar
gpp
gpp is offline
while gm and dodge are putting good old v 8 motors in there vehicles with 400 plus hp without power adders ford wants to shove a 6 cyclinder down our throats and charge out the wazoo for it.
Old 05-15-2009, 09:06 PM
cpdorroh's Avatar
cpdorroh
cpdorroh is offline
Ford Announces Pricing on 2010 Lincoln MKS With EcoBoost
Hopefully that $7k isn't just for the engine. Maybe when you get the ecoboost, it requires several other premium option packages with it, inflating the price.
All this time they have been saying it would be around a $1k premium, which wouldn't be that bad. If it is a $7k option in the trucks, I can tell you right now that thing will be a huge flop. That wouldn't make sense to even offer it as an option at that price, unless it got at least (insert rediculously high number here)mpg ....even then .
Old 05-15-2009, 10:05 PM
powerstroke72's Avatar
powerstroke72
powerstroke72 is offline
Here is a great write-up on the performance of the Eco-Boost in the Lincolns:
First Drive: 2010 Lincoln MKT EcoBoost and MKS EcoBoost
Old 05-15-2009, 10:39 PM
SteveVFX4's Avatar
SteveVFX4
SteveVFX4 is offline
yeah, if you read the article is says it's part of a package with upgraded rims, HID lights, etc., that don't come on the base model car. I'm sure it will be a standalone option on the F150.
Old 05-15-2009, 10:56 PM
powerstroke72
Yeah. In reading that, I noticed the same thing. The link about the pricing being announced compares the Eco-Boost "top of the line" model to a base model. Big difference in equipment. I would guess the stand alone option of the engine only to be about $1k-$2k.
Old 05-16-2009, 03:35 AM
PowerStrokeHD's Avatar
PowerStrokeHD
PowerStrokeHD is offline
Here are some base vehicle prices that should give a little better representation since they are comparing AWD to AWD...
2010 MKT AWD - $46,990
2010 MKT AWD EcoBoost - $49,995
Equipment that is standard with the EcoBoost AWD which is not included with the regular AWD...
Battery - 78 AMP
Exhaust - Dual Exhaust with Dual Chrome Exhaust Tips
Wheels - 20" Polished Aluminum
Tires - P255/45R20
Badge - EcoBoost
2010 MKS AWD - $43,585
2010 MKS AWD EcoBoost - $48,585
Steering - Electric Power Assist
Wheels - 19" Premium Painted Aluminum
Tires - P255/45R19
Badge - EcoBoost
Old 05-16-2009, 07:07 AM
pkvir's Avatar
pkvir
pkvir is offline
I thought the ecoboost was an engine replacement for the modular engines, along with the 5.0 and 6.2. I was expecting it to be the base engine, not an option.
Old 05-16-2009, 07:48 AM
cpdorroh's Avatar
cpdorroh
cpdorroh is offline
Wow! Look at that torque curve! It peaks at 1500 rpm and stays there until 5,250? As skeptical as I have been of this new engine, I have to admit that is impressive.
As far as the price is concerned, the upgraded wheels and HID headlights could easily account for $2-3K of the upgrade price, not to mention the other required options.
Old 05-16-2009, 09:06 AM
powerstroke72
My thoughts exactly...that torque curve is insane!
Old 05-16-2009, 09:59 AM
REDFORDFX4's Avatar
REDFORDFX4
But Only 24mpg in a car, should be able to get atleast 30+ from that engine in a car the regular 3.5 is rated at 27 in the 2010 Fusion.
Old 05-16-2009, 12:06 PM
PowerStrokeHD
The MKS and MKT factory order guide shows HID headlights to be standard equipment on all MKS's and MKT's, even the base model FWD's...
Old 05-16-2009, 01:11 PM
BLK94F150's Avatar
BLK94F150
BLK94F150 is offline
I guess if you're looking from a performance standpoint it's pretty good, but not from a MPG standpoint by any means.
If I wanted MPG, I'd defintely be going for the Fusion based hybrids.
Mike
Old 05-16-2009, 02:36 PM
idealtrucks's Avatar
idealtrucks
idealtrucks is offline
This isn't supposed to be the mileage getter though, right? Keep in mind it still has 355 hp. I'd say that 24 mpg is pretty good for that power level. The milage will be awesome when they do it for a small 4 cylinder that has the same power as the current v6.
Old 05-16-2009, 06:27 PM
tseekins's Avatar
tseekins
tseekins is offline
Received 1,221 Likes on 803 Posts
Ditto. I'm very concerned about the base engine for the F-150 and if a premium price will be added to the truck that is equipped with this motor.
Tim
Quick Reply: ecoboost
