best bio process??
Old 06-08-2008, 10:50 PM
mklemin's Avatar
mklemin
mklemin is offline
best bio process??
ok im new on this side of the forum and i was wanting o know the best way of making bio? if seen alot of differnt ways soe just seem cooky though i would ask you all who have been doing it. thanks
Old 06-09-2008, 09:12 AM
TXHillCountry's Avatar
TXHillCountry
TXHillCountry is offline
Go to a reputable site like BioDieselNow - Renewable biodiesel fuel and research the info there, and browse the forums.
TX
Old 06-09-2008, 11:02 AM
Phydeaux88's Avatar
Phydeaux88
Phydeaux88 is offline
First lets get straight what making Bio Diesel (BD) means.
There are sites that claim to make BD by adding some secret chemical plus gasoline and/or other ingredients to vegetable oil. That is NOT Bio Diesel.
Bio Diesel is produced by a transesterification process in which the vegetable oil molecule is torn apart producing 1 molecule of glycerol and 3 molecules of BD. While there is more than one way to accomplish transesterification the most common is the base (NaOH or KOH) alcohol (MeOH or EtOH) reaction in some kind (and there are several) of reactor vessel.
The site below will provide you with a good education in how to make BD and give you plans for an Appleseed processor (reactor).
Welcome - Collaborative Biodiesel Tutorial Website
Old 06-09-2008, 10:55 PM
mklemin's Avatar
mklemin
mklemin is offline
Ok thanks guys i had seen these sites there is just a mass of info out there just wanted a place to start. thanks again hopefully i will be on y way to makin my own bio here in the near future.
Old 06-12-2008, 12:14 AM
mklemin's Avatar
mklemin
mklemin is offline
so with an appleseed processor you can only make what the waterheater will hold in gallons at one time and that takes a few days to process. how do you make it in bigger quantities? can you?
Old 06-12-2008, 07:09 AM
TXHillCountry
Right. the conversion / processing tank size is your limitation in batch size. So, you can use a larger tank, or, run parallel tanks. Also, if you seperate your processing, washing and drying tanks, you can increase your rate of production since you can have one batch processing, another washing, and a third drying.
TX
Old 06-12-2008, 11:52 AM
Phydeaux88's Avatar
Phydeaux88
Once you are thru the reaction cycle all you have to do is move the batch to a settling tank and you can begin another batch in the reactor.
The total volume you can have in various stages will be limited by available room and the number of tanks you have that is a settling tank, a methanol recovery tank, a wash tank, etc.
I would recommend you consider methanol recovery and dry washing instead of the water wash methods found on most How To sites.
Methanol recovery saves money.
Dry wash gives a better quality product and reduces problems.
kylebryan
Bio-diesel, Propane & Alternative Diesel Engine Fuels
05-10-2010 08:36 PM
robinsonpowerstroke
49
05-27-2008 09:28 PM
westtntrucker
15
07-13-2006 04:17 PM
Downsized2X
11-08-2005 07:46 PM
Quick Reply: best bio process??
