Swap big tow mirrors for smaller sissy mirrors.
Here's the story:
My wife drives the Excursion and wants to sell it because "it is too big". Well she has driven this thing no problem and liked it for over a year and a half.
This all starts when she high fived another trucks mirror with hers and all of a sudden the EX got 3 feet wider to hear her tell it. "It's too big" ( now say that in a squeeky voice)
I finally got her to agree to keep it if I put the smaller mirrors on there that I have seen on other Excursions.
Has anybody done this swap or does anybody want big mirrors in exchange for their small ones?
Where would be the best place to find some? I looked at e-bay and found some but the auction ended too fast.
Will this swap be a plug and play like I hope it will be?
Ours is a 2000 model. Will the blinkers work in the mirror? Ours don't have them now.
the swap is easy if you have the right plug. but I wouldn't think she will like it with the smaller mirrors, but then again woman tend to never use there mirriors anyway. (general statment)
I would give you mine, but I already gave them away cause I like my big mirrors. helps me see the smoke better when romp the little cars. hehe
What plug will I need?
I can splice if necessary but prefer npt to. I saw some on ebay ,too expensive, butthey had several plugs big and small. looked like adapters. Then i saw some that only have a 2 prong plug. I will explore what I have tonight and compare to what I find. I guess I may have to wire the blinker option myself directly into the harness.
Why do you think she won't like the smaller mirrors?
well I went the other way. if I remember right the plugs on the Non-heated/blinker type is a round plug. but when I up-graded to the bigger mirriors I need an adaptor to match the rectangle plug. then I ran an extra wire from each, cause I did not have heated mirrors before to a switch so I can turn them on manually when I need them. if there new they should come with the adaptor. I would take my door panel off to confirt what plug you have. I am guessing a white round one wiht three wires. (assuming you have power to them, but that is it)
I only said that she might not like the smaller mirrors cause there smaller and when you are used to the big ones its just different. they both work, but I like my mirrors bigger to see more. I just joked about woman not using them, cause I know many that Dont even look. and its scares me.
I am sure others will chime in. I have only done this job once.
WOW. Man you guys are helpful. I pulled the panel last night and I have two plugs. One is a small two prong with both black wires and the other is a white plug with purple, yellow and green wires in it. It is heated and power and it is a 2000 model. I assume the black ones are for heat and the others are for power.
I think it would be awesome to have heat, power AND the blinkers that are made in the mirror. I imagine I could wire the blinker but it is not necessary.
Thanks to all you guys that offered your lights to me. I should take one of you guys up on it. Reps will be sent to all for the awesome gesture. I will send some of you a PM on the mirrors.
MAN YOU GUYS ARE AWESOME. I am just a temporary transplant from the OBS column and you still treat me like family. Kool
