Sea Foam in brake booster line?
#31
pitrow, sbclemens and SPreston2001,
Thanks for the help and the info. I now understand. I am very familiar with the cloud of smoke that you all reference, I use Sea Foam in my motorcycle and outboard motors about twice a year when I work on them.
I may have my next weekend project with my wifes '97 Expedition.
Thanks again,
Ginzu
Thanks again,
Ginzu
#32
Hey guys I did the Sea Foam in my brake booster line. I used about 1/2 of the can and let it sit for about 20 min, only thing is that it only smoked for about 10sec and that was it wasnt even alot of smoke. I was going to do it again in a few weeks what do you think? O ya it seems like the idle is smoother now. I used the rest of in in my gas tank.
Thanks ~Gage~
Thanks ~Gage~
#33
If you didnt get alot of smoke, then that usually means you didnt have alot of carbon buildup in your engine. I know people use a full can for each application (brake booster, crankcase, and fuel tank) when they do a treatment and they usually get a huge white cloud of smoke. Nevertheless if you feel a smoother idle, then you know it did its job.
#34
You should be glad there wasn't a lot of smoke. Less smoke means less build up, so less smoke is good. Yamaha sells a product for their 2 stroke engines called Ring Free, but it's very expensive so a lot of people use Sea Foam as a substitute. 2 strokes are prone to carbon build up because they burn oil with the gas. They build carbon on piston crowns and ring lands. 4 strokes do this too, but not to the extent that 2 stokes do because 4 strokes don't burn oil with their gas or at least they're not desiged to burn it. The problem with EGR is it leaves behind a nice thick coating of tar and soot on your entire intake over time. Seafoam is like a chiminey sweep in a can, but even Sea Foam can't get rid of all the trash that a properly functioning EGR system can leave behind. EGR is the product of the EPA run amuck, but it is a big money maker for Ford mechanics and dealerships.
#35
#36
I did my first Sea Foam treatment at about 130k and also did not experience the big cloud of smoke. Which was something I was looking forward to since I'm easily amused. Ellanboggs has brought up a good point. I've your engine isn't burning oil, there will be less carbon deposits than found on an engine that does burn oil. Another factor that weighs in is the quality of gas that you run. Where I live we have "special" blends that burn cleaner thus producing less carbon deposits. So if you live in an area that has all that special stuff added to the gas, then that also may explain the lack of the big cloud. I think once a year in the brake booster and half a can in the fuel tank every fourth fill up would be sufficient.
#40
#41
The only way you can hydrolock the engine is to pour liquid into the intake with it not running and have it run down into a cylinder with an open intake valve. If you get enough liquid in there, the piston cannot compress it in order to go past top dead center. If the engine is running you cannot hydrolock the engine.
#42
#43
#45
I did the seafoam on my 90 ford f150 with a 351 and it was a good smoking fun time.. I had neighbors coming out of the house to see what the heck I was doing. It cleaned it pretty good I guess because it idles nice and smooth and purrs like a kitten now. Was having some rough idling before and it cured it. I believe in it.
