2 bbl. Motorcraft
Old Jun 8, 2008 | 01:31 PM
bigfoot22's Avatar
bigfoot22
2 bbl. Motorcraft
I have a 2 bbl. Mototrcraft carb.on a '74 360,auto,2wd.Anyone with a diagram on the vacum lines hookup on this carb?and where the lines go to.Any pics of one where I can download? Thanks so much.
Old Jun 9, 2008 | 05:41 PM
fmc400's Avatar
fmc400
MSEE
I don't have a diagram, but it's pretty easy to describe. Not very many are on the carburetor itself. There are at most two spark ports on a 2 barrel. One will be on the front of the carb, underneath the fuel bowl; I believe it is the driver side. Use that for your vacuum advance on your distributor. You may have one on the passenger side under the choke housing for EGR, but I wouldn't imagine you have it on a '74 truck unless the motor came from a car originally. You may or may not have a large 3/8" port on the back of the carb; that is for your PCV valve. That's it for the carb itself. The rest of the vacuum lines run off the manifold.
cowboyfordlord
Dec 3, 2012 08:17 PM
otis302
Mar 26, 2011 11:53 AM
paintinpevs91
Feb 4, 2011 10:58 PM
300/6 Freak
35
Dec 23, 2010 12:00 AM
serving_time
89
May 25, 2004 07:25 PM
