Hydrogen and Oxygen generator on a v10 - Ford Truck Enthusiasts Forums
Modular V10 (6.8l)
Old 06-07-2008, 06:30 PM
nm1sks's Avatar
nm1sks
nm1sks is offline
nm1sks is starting off with a positive reputation.
Hey I ran across this. Is this for real? anybody out there tried this? Says it can add 25-50% better fuel economy.
Super Green Fuels - Home
Old 06-08-2008, 10:45 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is online now
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
No, it isn't real. It's there to separate you from your money.
Old 06-08-2008, 11:46 AM
meanv10's Avatar
meanv10
meanv10 is offline
meanv10 is starting off with a positive reputation.
Some of the diesel guys have tried homemade kits, that use's electrolysis to separate the Hydrogen and oxygen and run it in there moters, here are some links
personally I dont think that there is a lot to be gained from doing this on a gas motor, unless you get a custom tune to utilize the injection, the only thing you will most likely do is screw up your AFR because you never tuned for it, but because diesels are compression ignition they can be leaned out more and dont have to monitor there AFR's as closely, just there EGT's. also I dont think that you could split the water molecules fast enough and in enough of a quantity to actually be able to even tune with it
But this is my opinion, read these and see what you think.
https://www.ford-trucks.com/forums/6...induction.html
https://www.ford-trucks.com/forums/7...on-thread.html
https://www.ford-trucks.com/forums/6...-hydrogen.html
https://www.ford-trucks.com/forums/6...t-blackie.html
Old 06-08-2008, 08:53 PM
Skoda's Avatar
Skoda
Skoda is offline
Skoda is starting off with a positive reputation.
mean v10 thanks for the links, more then some thing to consider, though from the links you have provided, it seems there having a hard time getting 2lpm none the less it's a step in the right direction
Old 06-08-2008, 09:23 PM
twce023587
twce023587 is offline
twce023587 is starting off with a positive reputation.
I seen something on the news today and the other week about a hydrogen oxygen fuel. But I have only seen it done on an older civic ( 65mpg confermed by news station) and a ford escort ( 45mpg again confermed), don't know if it would do good on a motor that requires alot more fuel than those.If it works like the news channel says, wonder how long before BIG OIL buys it up?????
Old 06-09-2008, 12:19 PM
dkf's Avatar
dkf
dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
Hydrogen generator for a gasser is a farse. Diesels seem to benefit some but a diesel is a completly different animal. I for one am not going to use some homemade pile of crap and experiment on my expensive truck like I've seen already. Just plain stupid in my book to TRY and save a mpg or two, its a work truck for gods sake.
A hydrogen generator and running completely on hydrogen is totally different. What the news guy failed to mention is power will be down with the hydrogen. Look at the numbers the SC V10 is making on hydrogen, far less hp and tq than a stock 99' V10. Hydrogen is the future in my book, but more needs to be put into it to make it practical, starting with a cheap clean way to generate electricity to make hydrogen.
Old 06-09-2008, 04:58 PM
meanv10's Avatar
meanv10
meanv10 is offline
My opinion Is that we sill go electric, with batteries and not hydrogen, look at the Chevy Volt and the Toyota, there using technology that we currently have and not trying to use next generation stuff that we dont have the technology for. Just my opinion,
Also I dont believe there is a thing as "clean energy" what people fail to realize is that if you and the rest of America buy an electric car and plug it into the wall every night (same goes for hydrogen and the amount of energy needed to produce it) were is the power going to come from? Coal? nuclear with all of its depleted uranium rods ( that we make into armor piercing shells) plus all those batteries are going to eventual wear out then they go to some land fill and instead of having to deal with c02 that trees can use you have old batteries with all there acid and a bunch of nuclear waste.
Also DFK the v10 that runs on hydrogen is still using the internal combusionto run a motor off hydrogen instead of gas, this really isn't the way that they want to use it, they are going to ry to use reverse electrolysis to bond the hydrogen and oxygen to create electricity, like an electric car and suposidly the only byproduct is water out the tail pipe. you may have known this but its just a heads up of how i understand it.
My whole point is that nobody gets a free lunch.
Old 06-09-2008, 05:43 PM
dkf's Avatar
dkf
dkf is offline
I think you pretty much covered it. Theres downsides to everything, they just need to figure out how to manage the waste products.
I think having a completly silent vehicle would take a lot of fun out of driving.
Old 06-09-2008, 07:26 PM
Krewat's Avatar
Krewat
Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Straight-cut gears, a BIG electric motor and lots of squealing rubber would take care of that for ya!
Old 06-10-2008, 01:37 AM
twce023587
I agree with you DKF. I bought a V10, not a v10. I was just stating something on the news. Glad ya'll could fill in the gaps for me.
To comment on the battery cars, I have heard that when they wear out it will cost you your first born to replace them.
Nabors
08-16-2013 05:00 PM
timmyboy76
12-17-2012 09:41 AM
Florida Native 72
10-03-2012 12:14 PM
cowmilker08
06-20-2010 07:18 PM
toddyw
04-01-2005 11:32 AM
Quick Reply: Hydrogen and Oxygen generator on a v10
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
