Archived CO Buy/Sell/Trade Ads - Page 3 - Ford Truck Enthusiasts Forums
Colorado Chapter Join Chapter, Leader:
  #31
Old 09-19-2007, 05:19 PM
skiziks's Avatar
skiziks
skiziks is offline
skiziks is starting off with a positive reputation.
Hello everyone,
Does anyone have a 2 barrel carburetor laying around that I can put on my newest 69 F250? I have a 4 barrel intake that will go on later but I need to get this running and mobile before that.
Thanks for checking out in the garage for me.
Larry
  #32
Old 10-06-2007, 08:56 PM
97 OBS_PSD!
97 OBS_PSD! is offline
97 OBS_PSD! is starting off with a positive reputation.
Talking Bully Dog W/ outlook pup for sale........
I have 1 chip for a 03'-07' 6L. It has an outlook pup. I totaled my 05 truck and decided to get a 97 7.3L. So therefore i can't use the chip. I have had the chip for about a month and a half. The chip hasn't been used, and is worth $890.00 all i'm asking is $500.00 for it so i can buy a chip for my new truck. Give me a call (303) 519-6869 Steven.
  #33
Old 02-03-2008, 10:57 PM
osue077's Avatar
osue077
osue077 is offline
osue077 is starting off with a positive reputation.
Trade me your front seat
I have a 97' f250 with gray captains with center console that I would like to trade for a 40-20-40. They are in pretty decent shape.
http://www.coloradopowerstrokeclub.c...ad.php?t=12180
If you are interested, please pm me at either site.
Travis
  #34
Old 02-04-2008, 11:26 AM
Frankenstang57's Avatar
Frankenstang57
Frankenstang57 is offline
Frankenstang57 is starting off with a positive reputation.
parting '91 f-150
I'm parting out a '91 F-150 4x4. It's an extended cab short box, white/gray, 351w/AOD. I believe it only has 58k on it since it is super clean. Anyhow, it's hit in the front passenger side hard. I'd like to get $650 for the motor/trans/tcase but can separate. I'd like to get $450 for the box complete with t-lights/bedliner/tailgate. Prices are negotiable and everything else must go! It is going to be crushed in 2 weeks since I'm lacking storage space. Gimme a call @ 720-938-5848. The truck is located in Loveland. Thanx for looking!
  #35
Old 02-17-2008, 10:13 PM
sfc11b
sfc11b is offline
sfc11b is starting off with a positive reputation.
As much as I hate to do it, I must sell this 74 Ford F-100 4X4, Long Bed with a 1964 390 B block (Service Block). $750. Passed Colorado Emissions in April 07. It has a new 600 cfm Holley 4bbl, Radiator, Coil, Lock-outs, wiring, carpet, etc. Primer Gray currently. Needs C-6 tranny (broken parking paw). Married transfer case NP203. Has 2 new front tires 33x14. Dont know how to post pics. Can send upon email or call. Active Duty Army, wife has Cancer and have no time or tools to work on it. Like I said, hate to sell but must. Thornton 720-872-6230. Have title obviously
SFC Chris Warth
  #36
Old 02-19-2008, 07:54 PM
Colo79Ford
Colo79Ford is offline
Colo79Ford is starting off with a positive reputation.
The only reason i am selling my truck is because my mom needs a place to live. I talked to the landlord and the eviction notice will be handed to my mom tomorrow.
1979 Ford F-250 4x4
400CI engine, rebuilt 3 years ago by Romeys on Federal.
Engine isnt too much special, .060 over, cast pistons, 8.0:1 CR, .484 / .510 hydraulic cam. edelbrock dual plane intake, Holley 650 carb, HEI ignition, finned Mickey Thompson polished aluminum valve covers. Flowtech headers that leak a little bit. Flowmaster mufflers that end right behind the cab.
Transmission is a rebuilt from Walker Transmissions in Arvada. Has been in since July 6th 2006. Torque converter and flexplate were also replaced at the same time.
Very small transmission fluid leak, smaller oil leaks from sender unit. Leaks just enough oil to be noticable, but does not drop in level between oil changes.
No carpet in cab, interior door panels are in rough shape, dash pad is cracked.
No rust on cab. Small rust beginning in bottoms of doors, Bed has typical 70's Ford truck rust above the wheel wells, and tialgate is rough from having a few too many 454's dropped on it.
Has a receiver hitch, and 4 pin flat trailer wiring. Reverse lights do not work on truck. Truck has car quest special push button starter, switched fuel pump and ignition. Autometer oil pressure, volt meter, and coolant temp gauges in small console over transmission hump.
Dana 60 rear end 4.10 will need brakes soon. Dana 44 front with manual hub conversion kit, 4.11 gears. NP 203 transfercase has a Doug Nash part time kit installed. Transfer case needs new shifter. Will go into 4x4 but but shifter will not put it far enough into 4x4 to lock in.
oil changed every 2000-2500 miles. I have done 3 transmission services, filter since new transmission has been put in. Cooling system has been fluched every fall since 2005. Front diff, rear diff, and transfer case fluids all changed yearly at a minimum, and changed every time after driving in water.
Tows great, pulled my chevelle "speed limit" and more up 285 when i lived in conifer. Pulled flloyd hill at 55-60 with the chevelle, and pulled georgetown hill, between georgetown and silverplume at 60 with chevelle on a trailer.
The only reason i am selling the truck is so my mom can have a place to live..
Id like to get $2250 for it and am pretty firm on that price....
Clear Colorado title in my name, and current insurance/tags. Even with the work i have put into it, it is still a 29 year old truck..Just alot of new crap on it.
I know no one else who buys this truck would race it..But with the setup right now it would be a loomy 16.47 1/4 mile, with small shot of N2O would be 14.47 1/4 mile. Has been as low as 14.32 in the 1/4
If someone buys it, I would like to remove the windshield banner, racing stickers on vent window and rear slider, and also remove the black on the hood and truck sides and spray back over where the black was with grey primer...
  #37
Old 07-12-2008, 03:43 PM
Hypoid's Avatar
Hypoid
Hypoid is offline
Hypoid has a good reputation on FTE.Hypoid has a good reputation on FTE.
F-S, V-8 Mustang:
1979 Ford Mustang Notchback 5.0
  #38
Old 08-30-2008, 12:18 AM
BigGrizz76's Avatar
BigGrizz76
BigGrizz76 is offline
BigGrizz76 is starting off with a positive reputation.
I got a 1977 Ford F150 for sale. $6500. Check my gallery for pics and recent work.
  #39
Old 09-01-2008, 09:33 PM
MineralStang
MineralStang is offline
MineralStang is starting off with a positive reputation.
I have a '76 F-250 Hi Boy for sale. Looking to see if there is any interest in it. Body is rough for sure and the driver side floorpan has rust issues. New clutch, reman 390 (less than 2000 miles on motor), 4-speed. Starts and runs well. Just seeing if there is anyone that would be interested. I love the truck, but I am getting married and need to buy something more practical. Thank you! Asking $1250.
Nate
303-257-5083 or to [email protected]
  #40
Old 01-14-2009, 02:15 PM
raebear
raebear is offline
raebear is starting off with a positive reputation.
1957 Custom Cab for sale
<HR style="COLOR: #d1d1e1" SIZE=1 itxtvisited="1"> <!-- / icon and title --><!-- message --><TABLE width="100%" border=0 itxtvisited="1"><TBODY itxtvisited="1"><TR itxtvisited="1"><TD vAlign=top itxtvisited="1">1957 Ford Custom Cab for sale. Pic's in Gallery. Overall decent to good shape, motor- I do not believe is the original and is totally shot anyway. Any interest let me know, thanks.
Ray
Price, Utah
</TD></TR></TBODY></TABLE><!-- / message -->
<!-- controls -->
  #41
Old 01-31-2009, 05:00 PM
jay54f100's Avatar
jay54f100
jay54f100 is offline
jay54f100 is starting off with a positive reputation.
Want to buy ZFs542 and np205
Does anybody know where i can pick them up. Please pm or [email protected]
  #42
Old 04-21-2009, 01:13 PM
samahi72
samahi72 is offline
samahi72 is starting off with a positive reputation.
Trying to sell my 60 F-100. Rear wrap window
Take a look at my profile to see my 1960 F-100 with the full rear wrap window. I would like $6750.00. Send me a private message. If you want to see additional pictures or information, let me know.
thanks
  #43
Old 04-23-2009, 04:50 PM
Dajacks1
Dajacks1 is offline
Dajacks1 is starting off with a positive reputation.
Parts needed
Does anyone in the area have a dipstick tube, dipstick, kickdown lever and shift lever for a c-6 transmission with a 460? I am putting the 429 back into my short bed and the transmission that was in it when I bought it is out of a car. Thanks for any replies. The truck is a 78 f-100 so need the stuff out of a 150 or 250 big block 2wd truck. Thanks
  #44
Old 04-26-2009, 01:41 AM
Oversize's Avatar
Oversize
Oversize is offline
Oversize is gaining momentum as a positive member of FTE.
Try checking w/ denver used ford parts they have alot of odd ball stuff there. If not there is a newer scrap yard off 58th and I25 the green building on the south east side near the grizzly rose bar. I dont particularly like the way the run things treat customers, but they do have some good stuff, including some older trucks.
  #45
Old 04-26-2009, 01:43 AM
Oversize's Avatar
Oversize
Oversize is offline
"Denver used ford parts" also goes by the name "Denver aFORDable" ask for Larry he is a real good guyand knows his stuff and will do a real nice job of helping you out, Alsothey are on the CAR network and can check around if anybody else has the parts your looking for.
Quick Reply: Archived CO Buy/Sell/Trade Ads
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
