Subs behind seat in standard cab 95 f150
I just purchased 2 12" Kenwood w3005 and am having trouble finding designs. I definatley want to build them myself and don't know if I should build 1 big box or 2 separate boxes. Need help building boxes. contact me via e-mail, need your expertise.
optikal to the rescue, i got dimensions for a standards truck box for a 12" woofer. 14" high x 21" wide x 5.5" depth 1 (top) x 8" depth 2 (bottom). total air space with .5" wood it .8 cubic feet. this is good for most 12"s. i have to mount another 1" piece of wood on the front of my box to accomidate my larger mounting depth infinity perfect but most should be fine. stuff it with a 1 lb bag of poly fill (wal-mart has it for $2.50 a bag) and this will fool the sub into thinking the box is a little bigger. enjoy! :-)
ok now that i have thought of it, most subs (10"s and 12"s) do need around .5-1 cube (10"s) and .75-1.25" (12"s) i gave a basic design for a standard 12" but u could modify it for a 10" by just cuttint he hole to fit (remember not to cut the hole exactly 10" read the cut out diameter or if its not avabile use 9 1/2" as a generic measurment). u can modify the box to fit more or less air space but the depths are pretty much standard. its hard to design a box for every single individual. i hope this makes sense. but we can lean u in the right direction. so, just lemme know if i can help ya out.
I have a 95 f150 standard cab and I have 2 12s behind the seats and 2 670 watt amps under one on each side and 3 ways in the doors. All pioneer premiere and the sub's are the shallow series. Sound amazing.
Sub box
I have a '95 f-150 with a bench seat, standard cab; I have made numerous sub enclosures for this truck. If you tell what subs you running i can send you a design. I compete in car audio and beleive it or not you can fit up to four 10" subs behind that seat and the seat will still go all the way back.
peakster
01-12-2024 04:26 PM
Jesusfreak_01_02
08-01-2017 06:48 PM
