Heater Hoses on 292
Heater Hoses on 292
Hey,, Dumb question here. Where does the return heater hose go on the 292? I have the outlet tufbe on the water pump, whichis a no brainer. I dont see any other place for a hose connection other than maybe on the top of the Intake at the thermostat housing.
thanks in advance.
Vern
thanks in advance.
Vern
Hey,, Dumb question here. Where does the return heater hose go on the 292? I have the outlet tufbe on the water pump, whichis a no brainer. I dont see any other place for a hose connection other than maybe on the top of the Intake at the thermostat housing. thanks in advance. Vern
Your profile sez 2007 F150...that's a rather unusual year and model to have a 292 Y block engine, doncha think?
Y block
There's a straight nipple (8M-18599) that attaches to the waterpump for the heater hose.
There's a stand pipe that screws into the intake manifold (some have a shutoff valve...these resemble a garden hose faucet [without the threads where the hose attaches] for the return hose...on some.
I'll wait till you tell me what you're working on, before going any further with the stand pipe application.
Stand pipe: I found two different types: B7A-18599-B = (replaced by C6AZ-18599-B) & C4TZ-18599-B / The difference as I recall, (the parts catalog doesn't say-that's typical of Ford) is one is taller than the other.
Edit: Found a desciption in the car parts catalog....One is curved, one isn't.
I'll see if any obsolete parts seller has one...brb
Bill,, When I come across a man with your knowledge and access to part numbers,, I don't mind sarcastic remarks. You are always willing to help any and all of us. I also have access to a small shop here in the Denver area that may have the part as well.
Once again Thanks for the info.
Vern
Vern
celsoglima
1983 - 2012 Ranger & B-Series
12-16-2016 09:06 AM
TheWhiteBeast
11-26-2010 10:23 PM
