Manual swap help
Old May 28, 2008 | 09:00 PM
operator exmark's Avatar
operator exmark
Manual swap help
I just finished an AOD to ZF5 conversion on my '90 F150 and it won't start. I turn the key to start and the CEL and ABS lights come on but nothing to the starter whatsoever. When I was working on the steering colum I accidentally broke the wire going from the auto shifter collar to the shift indicator on the dash leaving the dash indicator at neutral. I am assuming this is why the starter relay is dead but the wire came out of the dash and I can't figure out how to electronically put my truck in park. Any help would be appreciated.
Old May 29, 2008 | 12:08 AM
Ford_Six's Avatar
Ford_Six
The neutral safety switch and backup light switch is on the transmission (AOD), you will need to figure out which wires to connect to bypass the NSS.
Old May 29, 2008 | 08:32 AM
subs1000w's Avatar
subs1000w
you can also just go back to the junk yard and get the transmission harness from the zf then unplug your aod harness and plug in the one from the zf and it will start
Old May 29, 2008 | 08:23 PM
operator exmark
Thanks guys I got a ZF plug and spliced it to the AOD harness and it starts fine. However when I took it out on the road the speedometer stopped working. At first it was very wobbly and seemed slower than my actual speed than dropped to zero. I am assuming the cable broke but I don't want to replace it and have it break again. Is there any difference between the AOD speedo and the ZF speedo?
Old May 30, 2008 | 10:07 AM
subs1000w's Avatar
subs1000w
could also be the speedo gear is bad my friend battled one in his explorer forever untill he bought a new one
