Modular V10 (6.8l)
It's spring (MAF) cleaning time!
Old 06-08-2008, 06:05 PM
hydro_37's Avatar
hydro_37
hydro_37 is offline
On my 2004 it is buried in the air box somewhere. I still cant find it????
Need to clean it but just having a problem locating it.
It was easy to find and clean on my 99.
Old 06-08-2008, 08:16 PM
twce023587's Avatar
twce023587
twce023587 is offline
Just cleaned mine this weekend along with throttle body. WOW, did my truck wake up.You guys were right on the money. Shifts are better, feels like more clydesdales are under the hood.Installing air intake and power programming this coming weeked. Can't wait on that!!!
Old 06-09-2008, 10:29 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
The MAF is in the back-end of the air box - You need to remove the inner insert - it just snaps into place.
Old 06-09-2008, 04:54 PM
hydro_37's Avatar
hydro_37
hydro_37 is offline
I will look for it tomorrow. Thanks Krewat
Old 06-09-2008, 08:38 PM
Monsta's Avatar
Monsta
Monsta is offline
Sit. Stay.
Here's what the MAF looks like. When you split the air cleaner housing, it is in the housing on the engine side.
Old 06-28-2008, 01:54 PM
Gage2502's Avatar
Gage2502
Gage2502 is offline
Thanks for the tips guys.
~Gage~
Old 06-28-2008, 04:32 PM
hydro_37's Avatar
hydro_37
hydro_37 is offline
I cleaned mine and it made a ton of difference. I un-hooked the neg battery terminal while I cleaned the MAF too.
Old 06-28-2008, 05:33 PM
FordxFour's Avatar
FordxFour
FordxFour is offline
Did mine last night, but did not disconnect the battery. Started it up, sounded the same, but when I hit the road all I can say is WOW!!! Don't know if it will help the mileage, but V-10's and mileage is like mixing water and oil. THANKS guys.
Marty
Old 06-30-2008, 03:27 PM
Gage2502's Avatar
Gage2502
Gage2502 is offline
Question, do you have to disconnect the battery?
I just cleaned the one on the Expedition and now time to clean the Gas Beast=o)
Thanks ~Gage~
Old 06-30-2008, 03:45 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
It's better to do it, so that the computer recalibrates itself ...
If I remember correctly, it does it at WOT for a certain period of time, but don't remember exactly....
Old 06-30-2008, 04:11 PM
Gage2502's Avatar
Gage2502
Gage2502 is offline
Thanks krewat, How long should I disconnect the battery? 15 min?
~Gage~
Old 06-30-2008, 04:23 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Leave the lights on, that'll drain the PCM's capacitors quicker too...
15 mins? I don't know, I always leave it off for a few hours, never really checked if codes disappeared any earlier. I've heard of others doing it for 15 minutes, can't vouch for them
  #28
Old 06-30-2008, 05:01 PM
Gage2502's Avatar
Gage2502
Gage2502 is offline
Wow a few hours, ok Ill do it=)
Thanks ~Gage~
  #29
Old 06-30-2008, 05:25 PM
reddogracing's Avatar
reddogracing
reddogracing is offline
Don't know if its right, but on a single battery car/truck I always take pos off and stick it to the ground so it makes good contact, and leave it. 15 ussualy gets it, on my own stuff, I leave it overnight, just to make extra sure , LOL. But they tell me i got something called ocd whatever that is, that makes me do things like that, and insist that you straighten the seat belts when you get ready to get out.
  #30
Old 06-30-2008, 06:35 PM
boxcar1974's Avatar
boxcar1974
boxcar1974 is offline
I just cleaned mine. I made a notiable difference. I can tell more in the shifts than the engine power. It does seem to pull harder above 3K RPM than before.
Thanks for the tip.
Quick Reply: It's spring (MAF) cleaning time!
