97 F-150 parasitic current drain
What is the maximun parasitic current drain for a 1997 F-150?
I just replaced the original motorcraft battery today after more that 10 years service! I replaced the battery and measured the charging voltage. The charging voltage was 14.46 VDC. I decided to look at the parasitic current. I removed the negative terminal and placed an amp meter in series. The current draw measures 220 ma. From searching WEB sites, I think that this may be a little high. Anything below 75 ma (0.075) is usually acceptable. I read a post from one web site that stated the Ford stated the parasitic current drain should be less than 500 ma (0.5 A). That seems way too high.
I disconnected the glove box and engine light connectors and that didn't help. I can get 60 ma if I disconnect the 15A Interior Lamps fuse or disconnect the 5A GEM (General Electronic Module) fuse or if I pull the Battery Saver relay. The only aftermarket device I have is an alarm system which was purchased and installed by Circuit City. I disconnected the connectors to the alarm system and no change in the parasitic current drain was noticed. Where is the GEM located on the '97 F-150? Any help would be appreciated.
expeditionph
1997-2006 Expedition & Navigator
04-24-2013 11:34 AM
