Go Back  Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
Reload this Page >
Anyone change their fuel filter or cabin air filter?
2004 - 2008 F150 2004, 2005, 2006, 2007 and 2008 Ford F150's with 5.4 V8, 4.6 V8 engine Advertisement
Old 05-26-2008, 10:48 AM
NY-Ford-Lifer
NY-Ford-Lifer is offline
NY-Ford-Lifer is starting off with a positive reputation.
Question Anyone change their fuel filter or cabin air filter?
I have an '04 F150 w/ 5.4 engine. Where are these filters and are they difficult to replace?
Old 05-26-2008, 11:21 AM
YOMAN
YOMAN is offline
YOMAN is starting off with a positive reputation.
I changed mine same as year as yours. I dont THINK theres cabin filter at all.
I can be wrong.
just BE CAREFUL with blue clip..do not overforce to pull blue clip.. its piece of cake. It took me about 5 mins job. so be expect some gas spill.
YOMAN!
Old 05-26-2008, 11:28 AM
NY-Ford-Lifer
Is that filter along the frame rail somewhere or back near the tank?
Old 05-26-2008, 11:32 AM
YOMAN
YOMAN is offline
yes its right by frame rail (silver can). Oh boy i think its on driver side by drivers door
YOMAN
Old 05-26-2008, 12:24 PM
BIGGDAWG900's Avatar
BIGGDAWG900
BIGGDAWG900 is offline
BIGGDAWG900 is starting off with a positive reputation.
yes it is on the driver's frame rail just in front of the tank, silver canister about 2 inches in diameter.
Old 05-26-2008, 06:20 PM
Twinsdad98
Twinsdad98 is offline
Twinsdad98 is starting off with a positive reputation.
As mentioned before, we don't have a cabin filter. I wish they wouldn't put that in our owner's manual!! Fuel filter is on the driver's rail. IF you have 4x4, it's next to the transfer case. There is a good article on the site about replacing your fuel filter. I wish I had reviewed it before I changed mine. Would have saved $18.00 for a new clip
Old 05-26-2008, 06:50 PM
triton_2002's Avatar
triton_2002
triton_2002 is offline
triton_2002 is starting off with a positive reputation.
there's a special tool (autozone) to disconnet the the fuel filter lines, works great, once you figure out how to use the tool........
Old 05-29-2008, 12:20 PM
KevinM
KevinM is offline
KevinM is starting off with a positive reputation.
There is no cabin air filter in an 04. The fuel filter is under the driver side conntected to the frame. You need the special tool to disconnect the couplings. If you screw it up you will be buying a new fuel line to the engine, and it will cost you some $$$!!!
Old 05-29-2008, 12:36 PM
Twinsdad98
Actually, Kevin, the dealerships now have just the clips so you don't have to buy the entire line. $16 for a pair of clips! Pink instead of blue, but you can get just the clips. Don't let any dealership tell you you can't...
Old 05-29-2008, 01:00 PM
KevinM
KevinM is offline
All I said was use the right tool or you will be buying a fuel line!
Bohen
6.7L Power Stroke Diesel
02-24-2017 03:18 PM
TerranE
21
01-03-2017 08:43 AM
Wyowanderer
09-20-2016 09:19 PM
brother steve
15
10-29-2015 02:24 PM
rockittsled
02-20-2014 09:13 PM
Quick Reply: Anyone change their fuel filter or cabin air filter?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
