Does anyone know if you can adjust the fog lights? They seem to be pointed down too far, I would like to push them up a tad. Thanks.
yes, all you need is a Phillips screwdriver, you will need to lay on the ground to get up under and behind the flog lights to turn the screw, sorry I forget if you turn them clockwise or counter-clockwise, turn them both the same number of turns’
