help! stuck valve
Old 02-11-2003, 04:46 PM
otto1's Avatar
otto1
otto1 is offline
Angry help! stuck valve
Im looking at buying a ford truck it runs but they say it has a stuck valve? is this comon for flats?
or is this flat on it last leg
any help with this would be great
Dan
Old 02-13-2003, 08:30 AM
2speed's Avatar
2speed
2speed is offline
help! stuck valve
A stuck valve isn't very much. What's the oil pressure like? Do a compression check and get the real story. Sometimes you can just whack the valve down with a screwdriver thru the spark plug hole and free it up. But it could have a broken spring, which is still no biggie.....
Old 02-13-2003, 06:57 PM
tcw's Avatar
tcw
tcw is offline
help! stuck valve
a stuck valve should be no big deal. i would check it out for yourself. never assume.
Old 02-19-2003, 09:58 AM
soso's Avatar
soso
soso is offline
help! stuck valve
a stuck valve is not that bad, when I got my flattie it sat out side for better part of a year. it was on it,s side and watter got in the exaust man. I had a lot of stuck valves in it I just took out the spark plugs,lots of tranny oiland a lot of taps with a wooden dowel freed them up.it purrs now.It's a good way to get to know your motor
queen of spades
11-16-2013 05:30 PM
wdmack
03-04-2012 06:20 PM
restoringmy46
Flathead V8 & Flathead 6
08-29-2005 09:13 PM
djmac
10-16-2004 01:56 AM
Quick Reply: help! stuck valve
