electrical issues
electrical issues
I'm having an issue with the altinator not charging the battery. The battery and altinator and regulator are new so i dont understand why the powers not getting to the battery to charge it. The battery and altinator have been tested and work. Any help would be appreciated, im in the Enid Ok area so if ur a local maybe u could look at it and help me out?
once i had that problem, after i changed the alt and reg, it stopped charging...i had to put a capasiter (sp?) on the regulator....i noticed my 78 had this thing on it but my 76 didnt....i just swapped it over and it has worked fine since...if your regulator dont already have one, there will be a yellow wire that isnt hooked up on the regulator, thats what it hooks to....i hope this helps....
