Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Brake Guides
- How To Change Disc Brake Pads
Step by step instructions for do-it-yourself repairs
- How To Replace Emergency Brake
How to rear hub seals and parking brake shoes
#106
No. Only the front hub bearings on a 4WD are non-serviceable. On the rear wheels, the outer bearing should already be in the stack of parts you have, and the inner is only held in by the seal. The seal should be replaced while you have it apart anyhow . . .
#107
Guys,
I'm collecting parts for my overhaul and the brake kit on Guzzle's site shows PN F81Z-2648-CA, but it says it's not compatible with my vehicle on ebay. Is my SRW e99 using these, or another part number?
http://www.ebay.com/itm/FORD-OEM-99-04-F-250-Super-Duty-Parking-Brake-Shoes-9U2Z2A753A-/262023481723?hash=item3d01d1097b&vxp=mtr
#108
According to the link you posted from ebay, all 1999 and up trucks use the same emergency brake shoes. And, if Guzzle (Bob) says they'll work, they'll work. My experience says that all the emergency brake shoes and hardware are the same. The variables that come into play are the rotors, brake calipers and pads that fit the calipers. Also the wheel seals may different, if you're pulling the hub to do this repair. Some Ford trucks have left hand threads on the drivers side rear spindle. That also varies from truck to truck.
#109
I just went thru my 06 SD front hubs and the needle bearing or my case, the spindle bearing is replaceable. On the 4x4...
#110
Does anyone have the part numbers for the hardware kit, ie: adjuster,springs,etc?
#113
#114
#116
#117
From this article:
93 f250: steps to replace a right rear axle seal..cab..4wd
Hub Nut Installation
- Install Hub Wrench Tool T85T-4252-AH on spindle.
- Tighten hub nut to 75-88 Nm (55-65 ft-lb). Rotate hub occasionally while tightening. NOTE: The hub nut will ratchet as torque is applied.
- Hub nut adjustment:
- For new bearings, after tightening to specification 75-88 Nm (55-65 ft-lb), ratchet back five teeth or notches on the hub nut. Five clicks must be heard during this operation in order to have performed it correctly.
- For used bearings, after tightening to specification 75-88 Nm (55-65 ft-lb), ratchet back eight teeth or notches on the hub nut. Eight clicks must be heard during this operation in order to have performed it correctly.
#118
I am in the process of doing my rear axle seals and I had an OEM 2 piece seal. The Ford dealer looked up the parts with the VIN number and gave me a 1 piece seal. The old seal broke apart when I removed the hub and I can't get the inner part of the seal that seats on the axle to come off, any suggestions?? The other question is am I OK going back with the 1 piece seal as a replacement?? Thanks in advance for your help.
#119
#120
Do not have a parts list. There are potentially 2 different seals for these axles, and they are not interchangeable. The seal surface on Ford axles came in 2 different diameters. If your axle had the 2 piece seal on it, then you better get the 2 piece to put back on it.
To remove the stuck piece, you will need a hammer and chisel, and you will need to be VERY Careful! Sometimes folding the back part of the seal down with a hammer can loosen it up enough to come off. This rarely works, but it's worth a try. The next option is to drive it off with the hammer and chisel taking extreme care to not damage the axle seal surface. If you can get the chisel imbedded into the part of the seal that's folded down, it won't be hitting the seal surface.
