WVO issues
WVO issues
i'm asking this for my neighbor, so hopefully i don't miss anything. he's running a dual tank wvo setup and the truck performs fine under most all conditions...with 1 exception...under heavy load. he said it acts like it doesn't get enough fuel (wvo). he said the fuel line is heated, but the tank doesn't have a heating element....so i said that may be the problem, oil is still a little thicker than the diesel to flow properly...but that's just my guess. his wvo tank is a 100 gallon bed tank (what farmers use for tractor fuel). does anyone know if there is an electric element that can be used in those tanks? does anyone know if that is, or could be, the problem? does anyone have any other suggestions?
his is an '02 7.3 auto.
thanks
thanks
thanks
thanks
Arctic Fox Inc. Products for cold weather, diesel fuel heating, tube bending and outdoor products
Check this link for the fuel heaters.
Rv Related? I did'nt even see anything that had to do with RV specifically... I just clicked the link above that was posted and in the 3rd column over to the right scroll down and look for the B1-B100 heating information. That what I figured would be best for your heating application. I have no doubt that they could offer you very educated opinion on your Buddy's SVO/ WVO system... Call em' up...
Alex
Alex
I could see how there could be some confusion with the RV company that makes and sales a brand called Arctic Fox that is based in Oregon and a company that makes fuel heater products named Arctic Fox that’s out of Minnesota.
ok, found it....big (actually little) difference in websites...artic-fox is rv stuff...arctic-fox is what i needed.
once he checks/changes the fuel filter...if it doesn't do any good, i'll have him move on to the heater.
or...he'll just say "f&$k it"...i'll just burn diesel when pulling the stock trailer.
either way, i'll pass on the info.
thanks again.
thanks again.
Swizzferd8
Bio-diesel, Propane & Alternative Diesel Engine Fuels
01-26-2014 08:43 AM
lio45
08-03-2012 03:52 PM
dzzavid
03-06-2008 08:04 AM
