So i have a question for anybody who can answer. i have the K&N 77 series CAI as well as a poweraid tb spacer. when i get in the throttle it has a good sound but when i level off around 2 grand rpm it has a constant high pitched whistle. not a good sound almost sounds like a belt squeaking is this normal on the 4.6? I am positive it is not the belts or pulleys it started after i put the CAI and TB spacer on. My question is,it normal to have such a high pitched constant whistle? Any ideas
Mine has a belt squeaking noise. I dont know what rpm i is though I dont have a tac. But my guess would be around 2 grand. Its hard to diagnose what it is because you have to be driving for it to make the noise. This is good news for you because it cancels out your mods being the problem.
check to make sure nothing came loose, and everything has a good seal, clamps, gaskets etc, on my civic with the stock intake on it, the air box came loose right at the throttle body and had pretty much the same thing when cruising you can hear it but not at idle or accelerating
