I have on 03 SD F250 SRW 2WD.
Can I buy a set of factory rims from an 06-08... I think they are 8 on 170mm? The basic question is did ford change the bolt offset or is it still the same?
06-08 rims sit deeper into the fender well..the tire will rub on the leaf springs when turning..you can use spacers.but im not a fan of them with a heavy truck..
