Attn Lifted Trucks - Page 2 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Attn Lifted Trucks
Old 05-27-2008, 10:58 AM
Overkill's Avatar
Overkill
Overkill is offline
FTE *******
Overkill is gaining momentum as a positive member of FTE.
The rubbing on the brake lines is the result of 12.5" wide tires on 8" wide wheels with 6" backspacing. This combination bulges the tire sidewalls more and also allows for more sidewall flex while cornering. Wider or more offset wheels would solve this issue but short of that you could simply bend the brake line supporting bracket inward a bit to move the lines away from the tires at full lock.
Old 05-27-2008, 11:38 AM
BillyBob69's Avatar
BillyBob69
BillyBob69 is online now
BillyBob69 is a splendid one to beholdBillyBob69 is a splendid one to beholdBillyBob69 is a splendid one to beholdBillyBob69 is a splendid one to beholdBillyBob69 is a splendid one to beholdBillyBob69 is a splendid one to beholdBillyBob69 is a splendid one to behold
The rubber missing from the rubber also allows for the lines to flex more under pressure, allows expanding making for a spongy feel. SS lines will not do this...and you can get longer ones and route them as you need.
Old 05-27-2008, 07:31 PM
KING's Avatar
KING
KING is offline
KING is starting off with a positive reputation.
The good news is that you guys are probably right. The bad news is that the tires are not exactly 12.5" because they are not in inches. They are metric -- 285/65/20 which I believe are 11.5" wide and they do not bulge. However, I'm sure however much wider they are over stock is to blame for the rubbing that is happening.
Where can I get steel braided lines and how much am I expecting to pay?
Old 05-27-2008, 11:36 PM
Jack_99V10
Jack_99V10 is offline
Jack_99V10 is starting off with a positive reputation.
Go on ebay and get them cheap.
I'm going to end up upgrading to SSBC brakes all around. They are 2 minutes down the road from me so I'm going to pull some strings with the guys I know working there.
Those lines do look rough though... be careful.
Old 05-27-2008, 11:50 PM
KING's Avatar
KING
KING is offline
Thanks.
I'll peel my eyes on ebay for them...
I'm honestly really worried about these hoses.
I will be going on a 700 mile round trip towing the 5th weel next week.
I'm going to work on resolving the issue by moving them further away from the tire.
Old 05-28-2008, 02:50 AM
BillyBob69's Avatar
BillyBob69
Your local 4x4 shop should carry them as an option when installing lift kits they sell. Check with them. Otherwise check your local Napa store or other parts store. Just make sure to get the length you need...add a couple of inches for suspension travel and re-routing.
Old 05-28-2008, 11:01 AM
rugermack's Avatar
rugermack
rugermack is offline
rugermack is gaining momentum as a positive member of FTE.rugermack is gaining momentum as a positive member of FTE.
It may be necessary to use zip ties to help hold them back out of the way.
Old 05-28-2008, 08:26 PM
KING's Avatar
KING
KING is offline
You beat me to to it, Patrick.
I picked up some heavy duty zip ties today to hold them back by tying to the frame somehow in the meantime while I get some steel lines.
Thanks to all for the great help. It is highly appreciated.
Old 05-29-2008, 12:50 AM
KING's Avatar
KING
KING is offline
I went ahead and moved them as close as I could to the sway bar end links and tied them with a zip tie. Here are some pictures.
FRONT DRIVER:
FRONT PASSENGER:
As you can see, I went ahead and added some electrical tape as a tool to tell me whether they will be damanged or not. I could not find chalk so I used what I had.
I'm really hoping this will do the trick for the meantime.
Old 05-29-2008, 06:05 PM
KING's Avatar
KING
KING is offline
So far so good!
No indications of rubbing but still shopping for steel lines.
It's getting there...
Old 05-29-2008, 06:56 PM
DAFBFD58's Avatar
DAFBFD58
DAFBFD58 is offline
DAFBFD58 has a great reputation on FTE.DAFBFD58 has a great reputation on FTE.DAFBFD58 has a great reputation on FTE.DAFBFD58 has a great reputation on FTE.
Superlift has extended brake lines that are steel braided
ATV PRO #11
02-28-2015 10:31 AM
timmygyu
1978 - 1996 Big Bronco
09-12-2011 10:51 PM
BlueOvalBud
32
04-20-2011 11:07 PM
cabloom300
06-24-2010 04:42 PM
bigfootford
38
08-22-2008 01:35 PM
Quick Reply: Attn Lifted Trucks
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
