No power brakes - moved from another section
Moved from brakes suspension and steering section....
First post, hope to learn alot from you guys....
Heres my problem.
Intermittent power brakes, happened while driving. Noticed there is power when brakes are applied while engine is above idle, but when it idles down while driving, no power assist.
Troubleshot with girlfriends dad. Hooked vacuum pump directly to brake booster, (disconnected vacuum manifold from system), and still no power at idle. I feel vacuum from line from pump is on my finger. He suggested that I replace booster, just want to see what you guys think.
I know the pump is creating vacuum, just dont know how much! Is there a spec as to what the pump should produce? Should I test it with some kind of gauge before I go replacing parts?
The booster itself has no visible cracks, holes, or corrosion, thats why her dad suggested replacing booster. Told me the diaphram inside can wear out letting vaccum pass.
I notice that on the pump the round thing, I guess its where the pump gets its air, is greasy. Figure its power steering fluid getting sucked up from the area where the resivoir is. Girls dad said that isnt the problem.
May or may not help, but the cruise has been intermittent sine I bought truck. Sometimes it works, sometimes it dont. Sometimes it even turns off while driving, figured it was a vacuum problem, just never dug into it.
Thanks for any input in advance, I got to fix it this weekend, and dont want to make a handfull of trips to the parts store!
Higgy
Heres my problem.
Higgy
x2 what Tim said, Vacuum pump.
Your CC is probably the sensor on the end of the master cylinder. They are prone to failure. Unplug it and see of there is fluid in the connector cavity. It should have continuity on it all the time...it opens when you step on the brakes. I would just replace it because they were re-called for starting fires on gas engine vehicles. No fires on diesels that I know of.
Just to throw something in here. My CC shuts off when I use my blinker. My diagnosis is the Multi function switch since sometimes when I turn on the left blinker the inside and front blinker don't blink but the rear does. Strange huh? just my .02
I agree start with the sensor at the end of the master cylinder first. They are cheap.
Also Welcome to FTE.
on
1 Post
Thanks all!
Thanks to those who pointed to the vacuum pump. I ONLY had to go to 5 different parts stores to find the part, all city driving without power brakes! To top it off, I didn't have the right kind of puller to swap the pulley, so I had to run up to a local shop and get it swapped, no charge, so that was cool. Thanks again everyone!
