New Reman. 351W Timing, Carburator or Ingnition Problem?
Have recently installed
Jasper remanufactured 351W
Rebuilt Holy Carb
new fuel filter, spark plugs, rotor, distributor cap etc.
Reoccuring Problems:
Rough Idle
Fouled Spark Plugs sometime up to 3
Lousey gas milage
Black Smoke
Mechanic
Scopes the engine
set fuel mixture
checks timing
cleans fouled plugs
and Test drives it.
I left the mechanics shop 4 times now (reoccuring problem),when I leave it runs fine until about 15 miles down the road, carburator loads up, it stalls out and black smoke out the exhaust. When I turn it off and try to restart only turns over once. If I let it set for an hour it starts up then I take it back to the mechanic and we start the process all over again. Can anyone please give me any help or advice.
Rebuilt Holy Carb
Rough Idle
Lousey gas milage
Black Smoke
Mechanic
Scopes the engine
set fuel mixture
checks timing
cleans fouled plugs
and Test drives it.
Guest
Posts: n/a
>Jasper remanufactured 351W Rebuilt Holy Carb new
>cap etc.
>Reoccuring Problems: Rough Idle Fouled Spark Plugs
>sometime up to 3 Lousey gas
>milage Black Smoke
>Mechanic Scopes the engine set fuel mixture
>checks timing cleans fouled plugs and
>Test drives it.
>any help or advice.
was the power valve checked. what about float level. both could lead to the conditions decscribed.
>cap etc.
>milage Black Smoke
>Test drives it.
>any help or advice.
>>cap etc.
>>milage Black Smoke
>>Test drives it.
>>any help or advice.
I will check on that and get back to you.
Thanks,
Bill Hays
>>cap etc.
>>milage Black Smoke
>>Test drives it.
>>any help or advice.
Thanks,
Bill Hays
In between the carb and the intake is what's called an EGR spacer plate and requires an additional gasket against the intake. This item is often overlooked because the plate usually remains still while the carb is removed.If this gasket is leaking internally,between the EGR port and carb ports,you will have a disturbed fuel mixture.As far as the cranking problem,it is likely to be insufficient cranking amps because of the battery,connections or just a bad starter.The carb and the cranking problem are 2 seperate problems.
Phillip
Phillip
bigric
03-27-2003 09:41 PM
mkbernier
04-05-2002 11:50 AM
